Solving for Particular Integral in Differential Equations: Arctan Definition
  • Thread starter Thread starter Zell2
    Integral
Zell2
I'm trying to find a particular integral to the differential equation on the attatched image, but I come up with two slightly different answers depending on the method I use. I suspect the problem (if it's not just me being very thick and making a silly algebra error) is the way arctan is defined but I can't see what I should do differently in either solution.
Attatched.
Thanks
?? You give just the answers and they look identical to me!
One has a plus thi one has a minus thi for some reason.
I think you mean phi, \phi
I haven't read the question, I probably wouldn't understand it, but perhaps Halls was giving a hint that its equal to zero?
My mistake sorry, meant phi. I think phi's only going to be zero in a special case, for most values of a,b,c,w it's going to be non-zero.
Does anyone have any other suggestions? The second version is the one that works in the differential equation but I still can't see why the first one doesn't.
Thanks
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
