Path of the particle on inclined plane
The discussion revolves around analyzing the forces acting on a particle on an inclined plane, particularly in static equilibrium. Participants clarify that the particle does not slide down due to the angle θ being set such that tanθ = μ, ensuring friction balances the gravitational component. They explore the relationship between tension in the string, friction, and the particle's motion, emphasizing the need to consider both x and y components of forces. The conversation highlights the importance of accurately resolving forces and understanding the direction of friction, especially when the particle is positioned at different points on the incline. Overall, the analysis aims to derive correct equations governing the particle's behavior under the influence of these forces.
  • #101
Vibhor said:
Could you please explain how does tension (acting at an angle) causes the particle to move down slope . I have thought about it but I am still unsure .
Suppose the particle does not move parallel to the y-axis when in the second quadrant. What direction would the friction force point? Could the forces sum to zero in this case?
  • #102
Thank you very much TSny . You have exhibited remarkable skills in solving this problem :bow:. I really appreciate your help . Thanks again .
