PDE, heat equation with mixed boundary conditions
The discussion focuses on solving the heat equation given by \(\partial_t u = 2 \partial_x^2 u\) over the interval [0,1] with mixed boundary conditions: \(u(0,t) = 0\) and \(\frac{\partial u}{\partial x}(1,t) = 0\). The initial condition is defined piecewise, with \(u(x,0) = f(x)\) where \(f(x) = 0\) for \(0 < x \leq \frac{1}{2}\) and \(f(x) = 3\) for \(\frac{1}{2} < x < 1\). The solution involves separation of variables leading to the eigenvalue problem, where the user is attempting to find the eigenvalues using the expression \(\sqrt{\frac{\lambda}{2}} = \arccos(0)\) and is exploring the general solution for \(u(x,t)\) as a series expansion.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the heat equation and boundary conditions
  • Knowledge of separation of variables technique
  • Basic concepts of eigenvalues and eigenfunctions
  • Study the method of separation of variables in PDEs
  • Learn about eigenvalue problems in the context of boundary value problems
  • Explore the Fourier series expansion for solving heat equations
  • Investigate the implications of mixed boundary conditions on solution behavior
Students and researchers in mathematics and physics, particularly those focusing on partial differential equations, heat transfer, and boundary value problems.
Hakkinen
solve the heat equation over the interval [0,1] with the following initial data and mixed boundary conditions.
[itex]\partial _{t}u=2\partial _{x}^{2}u[/itex]
[itex]u(0,t)=0, \frac{\partial u}{\partial x}(1,t)=0[/itex]
with B.C
[itex]u(x,0)=f(x)[/itex]
where f is piecewise with values:
[itex]0, 0<x\leq \frac{1}{2}[/itex]
[itex]3, \frac{1}{2}<x<1[/itex]
after separation of variables where [itex]u(x,t)=h(x)\phi (t)[/itex]:
[itex]h''(x)=-\frac{\lambda }{2}h(x)[/itex]
[itex]\phi'(t)=-\lambda \phi(t)[/itex]
gen. solution to h is
[itex]h(x)=a\sin \sqrt{\frac{\lambda }{2}}[/itex] the constant with the cos term is 0 from initial value
I'm stuck trying to find the eigenvalue
[itex]h'(1)=\frac{\lambda }{2}a\cos\sqrt{\frac{\lambda }{2}}=0[/itex]
[itex]\sqrt\frac{\lambda }{2}=\arccos 0[/itex]
I'm not sure what expression with n to use for arccos of 0. npi/2 won't work, or (n+1)pi/2, is this the right procedure though?
Any help is greatly appreciated!
EDIT:
I'm trying [itex]\frac{\pi }{2}+n\pi[/itex] now to solve for the eigenvalue
So for the general solution of u I have [itex]u(x,t)=\sum_{n=1}^{\infty}A_{n}\sin [\frac{\pi}{2}(1+2n)x]\exp -2t[\frac{\pi}{2}(1+2n)]^2[/itex]
and the coefficient A_n given by
[itex]A_{n}=\frac{12}{\pi(1+2n)}\cos \pi(1+2n)[/itex]
There was another cosine term with pi/2 in the argument that was always zero for any n, but is this an acceptable way to leave the coefficient expression?
