How to Calculate the Theoretical Voltage of a PEM Fuel Cell?
To calculate the theoretical voltage of a PEM fuel cell, the Nernst equation is applied, considering the electrochemical reaction of hydrogen and oxygen to produce water. The standard potential (Eo) for this reaction is 1.229 V, not 0 V, and the partial pressures of reactants and products must be determined using Dalton's Law. After recalculating the pressures, the theoretical voltage per cell is found to be approximately 1.222 V, leading to a total of 14.667 V for a 12-cell stack. The measured voltage of 7.2 V indicates a significant efficiency drop, raising questions about the discrepancies between theoretical and actual performance. Understanding these differences is crucial for optimizing fuel cell efficiency.
clementlee87
Hi, I'm working on a commercially available PEM fuel cell and I'm trying to calculate the theoretical voltage of the cell:
The only electrochemical reaction considered is H2 + 0.5O2 --> H2O
And I understand that I need to use the Nernst equation:
E = EO - (RT / 2F) ln (PH2O / (PH2 * SQRT(PO2))
The anode side in is pure hydrogen from a gas canister at 300 ml/min at 5 psi
The cathode side in is air from ambient at 1 atm
The operating temperature is 50 C, or 323 K.
How can I determine the partial pressure of water produced? If I assume that the water produced is at the vapor pressure of water at my room conditions, it should be at approximately 1584.9 Pa (50% RH at 28 C).
And if I used these pressures,
P H2O = 1584.9 Pa
P H2 = 34483 Pa
P O2 = 21287 Pa
I would get ln (PH2O / (PH2 * SQRT(PO2) = -8.063. This in turn gives me 0.112 V. For this 12 fuel cell stack, that would be equal to 1.344 V. However, the produced voltage when measured with a handheld ammeter reads about 7.2 V.
So wouldn't that mean my efficiency is more than 100%?
Thanks for your help! I need it as soon as I can.
Chemistry news on Phys.org
clementlee87 said:
(snip)The anode side in is pure hydrogen from a gas canister at 300 ml/min at 5 psigauge
(snip)P H2 = 34483 Pa+~100kPa
(snip)
questions?
Ah, thank you, Bystander. A slight on my part.
However, now that I've modified this,
P H2O = 1584.9 Pa
P H2 = 34483 + 101325 = 135808 Pa
P O2 = 21287 Pa
the quotient term ln (PH2O / (PH2 * SQRT(PO2) = -9.434, and my voltage is still only 0.131 V only. Also, I would like to confirm: for this reaction the standard potential Eo is 0 V, right?
Eo is the standard potential of the cell or the potential at standard conditions, i.e. 25C, 1 atm. It is not 0V its 1.229V for a H2-O2 reaction. You can get find this value from any standard reaction table or simple thermodynamic analysis.
The concentrations of the reactants and products are partial pressures over the total pressure. You don't need to determine absolute pressures for each, only the mole faction (Dalton's Law).
So if you are using regular air with H2 at 5 psig you would have,
Eo = 1.229V
PH2 = 1.34 atm
PO2 = 0.21 atm
At a temperature of 323K and 1 atm, water is in liquid form which means you can assume it be incompressible. Because of this you can assume your products, or PH2O to have a pressure of 1 atm.
So using the Nernst Equation (the form I like)
E = Eo + RT/nF ln(PH2 x PO2^0.5 / PH2O)
You get a voltage of
1.222V per cell or 14.667V for your entire 12 cell stack.
Pop quiz, why is your theoretical voltage at your operating conditions less than 1.229V even though you have a higher concentration of H2 on the anode? Also, if your stack voltage has a theoretical value of 14.667V, why are you only reading 7.2V?
BTW, an ammeter measures current. A voltmeter or electrometer measures voltage.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
