Period Calculation for Physical Pendulum
  • Thread starter Thread starter aam11
    Pendulum
aam11
How do you calculate the period of a physical pendulum?
Hint:
Calculate moment of inertia.The mass is known.'g' is of course known.
where I is the moment of inertia; in this case I = mr^2/2. When θ is small,
and therefore the expression becomes
