Period of Pendulum Before String Extension
  • Thread starter Thread starter zeralda21
    Pendulum Period
The discussion revolves around calculating the period of a mathematical pendulum before its string is extended by 60 cm. The formula used is T=2pi*sqrt(l/g), where l is the length of the pendulum. The user initially calculated the length incorrectly, leading to an erroneous period of 1.83 seconds instead of the correct 0.9 seconds. Upon reevaluation, the user identified a mistake in their arithmetic, confirming that the correct length is 1/5, which aligns with the accurate period. The final conclusion emphasizes the importance of careful calculations in solving physics problems.
zeralda21
For a mathematical pendulum, you notice that if you extend the string with 60 cm, then the time of one period will double for small oscillations. What was the period of time before the line was extended?
T=2pi*sqrt(l/g) where l is the length of the pendulum.
If I assume that the first pendulum has a length l, then the period will of course be: T=2pi*sqrt(l/g). If I now extend it by 0.6m, the period will double: 2T=2pi*sqrt((l+0.6)/g) which is equal to T=pi*sqrt((l+0.6)/g).
Now I set my first equation equal to the last one:
T=2pi*sqrt(l/g)=T=pi*sqrt((l+0.6)/g) , squaring LHS and RHS----> 4l/g=(l+0.6)/g ---->
4l=l+0.6---> l=5/6. If I insert this value of l into my first equation I get that T=1.83 seconds which is wrong. Correct answer is 0.9 seconds.
Or is there another way of solving?
Looks OK.
4l=l+0.6---> l=5/6.
Redo that last step!
Doc Al said:
Looks OK.
What a mistake..I assumed 0.6=5/3 instead of 3/5. The length 1/5 is correct and matches with period. Thank you very much sir.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
