How Do You Determine the Permeability of Steel Screws Used in Electromagnets?
To determine the permeability of steel screws used in electromagnets, it's important to recognize that the material is likely carbon steel, which has varying permeability based on its formulation. The best approach is to refer to the manufacturer's specifications for the specific type of steel used. Alternatively, measuring the permeability directly with appropriate instrumentation is suggested, such as using a gaussmeter made from a multimeter and a compass. Resources and instructional videos are available online to assist with this measurement process. Understanding the permeability is crucial for accurately predicting the B-Field strength of the electromagnet coils.
Jdo300
Hello All,
I'm working on a project involving the use of electromagnets and I am trying to do some calculations to predict the B-Field strength of the coils I make. For the core, I'm just using some common 1/4-20 steel machine screws (the common ones you can get from Home Depot and Lowes) but I'm not sure how to account for the permeability of the steel in my calculations.
Does anyone have any idea how one might determine this information? I know that the material will not have a fixed value (BH Curve) but if I could know what kind of steel is used, that would help a lot. Does anyone have any idea about this?
Thanks,
Jason O
The material is likely carbon steel. But there are many formulations of carbon steel with different permeabilities. You'll have to refer to the manufacturer.
Measure it. :)
I would just measure it, but that would require some instrumentation. What sort of electrical instruments do you have available to make measurements?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
