Pf = Pi * (Vi/Vf)^5/3 (since gamma = 5/3 for a monatomic gas)
  • Thread starter Thread starter 125.6
The discussion centers on the adiabatic compression of an ideal monatomic gas, where the initial pressure is 1 atm and the volume is reduced to 1/8 of its original size. The final pressure is calculated using the formula pf = pi(Vi/Vf)^(5/3), resulting in a final pressure of 32 atm. The final temperature is derived from the ideal gas equation, yielding a temperature of 487.5 K. The participants clarify the relationship between pressure, volume, and the adiabatic process, emphasizing that for ideal gases, P*V^gamma remains constant. Understanding the derivation of the pressure equation is a key point of confusion for some participants.
125.6
One mole of an ideal monatomic gas, initially at 1 atm pressure, is surrounded by adiabatic walls in a container of volume 0.01 m3 . The gas is compressed until the volume is 1/8 of the original volume. Calculate the final pressure and temperature.
^^ I'm having problems following this question. Its only a short answer, but I'm confused none the less!
A: pV^5/3 = constant.
pf = pi(Vi/Vf )^5/3 = 1(8)^5/3 = 25 = 32 atm.
Tf = pfVf /nR = 32 × (0.01/8)101325/8.314 = 487.5 K
I understand the last line in normal ideal gas equation, but the first two lines, which reference the equation: pV^5/3 = constant has thrown me, i don't know how the second line follows (where does pf=pi*(vi/vf)^5/3 come from? i see its similar to the constant equation
For adiabatic processes (no heat exchanged withthe surroundings) in ideal gases, P*V^gamma = constant. Gamma is the ratio of the heat capacities at constant pressure and constant volume. For an ideal monatomic gas, C_v = 3/2 * R, and C_p = 5/2* R, so gamma = (5/2 * R) / (3/2 * R) = 5/3.
http://en.wikipedia.org/wiki/Adiabatic_process
Yeah, thanks
The part i still don't understand is how the equation pf = pi*(vi/vf)^5/3 follow?
125.6 said:
Yeah, thanks
Pf * Vf^gamma = constant = Pi * Vi^gamma
Pf = Pi * (Vi/Vf)^gamma
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
