How is Heat Transfer Calculated in Ice Melting Problems?
In summary, the original amount of ice had a mass of 80.0g and was at a temperature of -15 degree Celsius. After adding 19.2KJ of heat, the final temperature of the ice is 0 degree Celsius and 30.0g of ice remains. The 19.2KJ of heat energy first raises the temperature of the ice from -15 oC to 0 oC and then melts as much ice as it can. The final temperature will not rise unless all the ice melts, which did not happen in this scenario due to not enough heat being supplied.
sdevgon
1. An amount of ice of mass 80.0g is in a freezer at a temp of -15 degree Celsius. The ice is removed from the freezer, and a total of 19.2KJ of heat is added to the ice. Determine the final temperature of the ice and the mass of ice (if any) which remains after the heat is supplied.
2. Ans is 0 degree Celsius, 30.0g of ice remains
I don't know know how to get that answer. Please help !
Thanks
What do you think happens when you add heat to ice at -15 oC? What happens to any solid when you add heat to it?
adding heat to ice will cause it to melt. But what confused me is 19.2KJ of heat energy. Because i keep taking 19.2KJ of heat energy in consideration when calculating the final temperature.
Not necessarily. Adding heat to a solid raises its temperature. It will start melting only if it reaches its melting temperature. So the 19.2 kJ of heat energy do two things: (a) first they raise the temperature of the ice from -15 oC to 0 oC and (b) whatever heat is left over melts as much ice as it can.
Why did that confuse you? Of course you should take it in consideration. The final temperature will not rise unless all the ice melts. Evidently, here you don't have enough heat to melt all the ice.
for your question. In order to determine the final temperature and mass of ice, we need to use the principles of phase change and specific heat capacity. First, we need to recognize that when heat is added to ice, it undergoes a phase change from solid to liquid. This means that the heat added is used to break the bonds between the water molecules in the ice, rather than increasing the temperature of the ice. This is why the final temperature is 0 degrees Celsius, as this is the melting point of ice where it transitions from solid to liquid.
To calculate the final temperature, we can use the equation Q = m * L, where Q is the heat added, m is the mass of ice, and L is the latent heat of fusion for water (which is 334 J/g). Rearranging the equation, we get m = Q / L. Plugging in the values, we get m = 19.2 kJ / 334 J/g = 0.057 g. This means that 80.0 g - 0.057 g = 79.943 g of ice has melted.
Now, we need to determine the final mass of the ice. We can use the equation Q = m * c * ΔT, where Q is the heat added, m is the mass of ice, c is the specific heat capacity of ice (which is 2.09 J/g°C), and ΔT is the change in temperature. Since we know that the final temperature is 0 degrees Celsius and the initial temperature was -15 degrees Celsius, we can plug in the values and solve for m. This gives us m = 19.2 kJ / (2.09 J/g°C * (0 - (-15)°C)) = 30.0 g.
Therefore, the final temperature of the ice is 0 degrees Celsius and the final mass of the ice is 30.0 g. I hope this helps clarify the process and calculations involved in solving this problem.
1. What is the difference between heat and temperature?
Heat is a form of energy that is transferred from one object to another due to a difference in temperature. Temperature, on the other hand, is a measure of the average kinetic energy of the particles in a substance.
2. What is a phase change in terms of physics?
A phase change, also known as a state change, is the transformation of a substance from one physical state to another. This can occur when the substance's temperature or pressure is altered.
3. What are the three states of matter?
The three states of matter are solid, liquid, and gas. A solid has a fixed shape and volume, a liquid has a fixed volume but takes the shape of its container, and a gas has neither a fixed shape nor volume.
4. How does heat affect phase change?
When heat is added to a substance, the average kinetic energy of its particles increases, causing them to move more quickly and spread out. This can lead to a change in the substance's state, such as from a solid to a liquid or from a liquid to a gas.
5. What is the difference between melting and freezing?
Melting is the process in which a solid substance changes to a liquid state, while freezing is the process in which a liquid substance changes to a solid state. Both involve a change in the substance's temperature and energy, but in opposite directions.
