Why Is Phase Velocity Defined as v=w/k?
Phase velocity is defined as v = ω/k, where ω is the angular frequency and k is the wave number, derived from the harmonic wave equation f(x,t) = a sin(kx - ωt). By rewriting the equation as f(x,t) = a sin(k(x - (ω/k)t)), it becomes clear that if x - (ω/k)t = s (a constant), then the wave's value remains constant, represented as a sin(ks). This indicates that the signal propagates in the positive x-direction at a velocity of ω/k. The trajectory of the signal can be expressed as x = s + (ω/k)t, confirming that the phase velocity describes how the wave's phase moves through space over time. Understanding this relationship clarifies the concept of phase velocity in wave mechanics.
asdf1
why is phase velocity v=w/k ?
Let us look at a typical harmonic wave, f(x,t)=a\sin(kx-\omega{t})
Here, a,k,\omega are constants, where a is the amplitude, k the wave number and \omega the frequency.
Rewrite this in the following form:
f(x,t)=a\sin(k(x-\frac{\omega}{k}t))
Do you see that if x-\frac{\omega}{k}t=s where s is a CONSTANT, makes the value of f constant as well (equal to a\sin(ks))?
But that means, that the signal value a\sin(ks) can be regarded as MOVING ALONG THE POSITIVE X-DIRECTION WITH VELOCITY \frac{\omega}{k}!
For, (remembering that s is constant) we have the trajectory for our signal:
x=s+\frac{\omega}{k}t
and this simply shows what the propagation velocity of our signal is..
@@a
"But that means, that the signal value can be regarded as MOVING ALONG THE POSITIVE X-DIRECTION WITH VELOCITYw/k !"
can you explain that a little clearer?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
