Photoelectric Effect: Measuring Stopping Voltage
Measuring stopping voltage in the photoelectric effect involves connecting a battery to the circuit and adjusting until the current reaches zero, rather than using a voltmeter. This is because relying solely on a voltmeter would be impractical, as it would require a large number of photo-electrons to generate a measurable voltage and would be affected by system discharge. Additionally, not all released electrons have the maximum energy, leading to a biased potential reading from a voltmeter. The distribution of electron velocities means that only electrons with sufficient energy contribute to the current once a certain voltage is reached. Therefore, determining the stopping voltage by measuring the current is a more effective and practical approach.
tomz
Hi everyone, a quick question on photoelectric effect.
Why measure stopping voltage by connecting a battery to the circuit and then adjust until current reach 0? Cant we just use a voltmeter?
Thank you!
In theory, you could wait until all the photo-electrons generate the voltage themself - but that would require so many photo-electrons that it is not practical. In addition, no isolation is perfect (especially with an attached voltmeter), the system would discharge itself.
Thanks. After some thinking I guess there is also the problem that not all electrons released have the theoretical maximum energy, so the potential get from a voltmeter will be biased
The distribution in velocities will just mean that it takes longer to reach the maximum voltage - the low velocity electrons will play no part in the process once the voltage is greater than their particular stopping voltage.
Finding the value of V that will stop the current would be a more practical way, I think - which is why it's recommended.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
