How many 420nm photons are emitted per second by an LED with a power of 10 mW?
  • Thread starter Thread starter XTEND
    Per Photons
An LED with a power of 10 mW emits light at a wavelength of 420 nm. The energy of a single photon is calculated using the formula E=hc/λ, resulting in a value of 4.7328E-19 J for 420 nm. To find the number of photons emitted per second, the power is divided by the energy per photon, yielding a final result of approximately 2.1E16 photons per second. Errors in initial calculations were identified, particularly in the conversion of units and exponent values. The correct approach confirms the emission rate of photons for the specified LED.
XTEND
An LED emits a light beam with a power of 10 mW. The wavelength of the light is 420 nm. How many 420nm photons are emitted per sec.?
E=hc/lamda is 2.95E-9
P/E= Photons emitted per sec.
(10*10E-3)(2.95E-9)=2.952E-11
2.95E-11 is wrong.
2.1E16 photons per/sec. is the answer
Your value for E is wrong.
h=6.626068 × 10-34 m2kg/s
okay.
(6.626x10E-34)(3.0x10E8)=1.9878E-25 / 420nm = 4.7328E-28
(10x10E-3) / (4.7328E-28) = 2.1129E25
This is still not 2.1E16
XTEND said:
okay.
You forgot to convert nm to m.
XTEND said:
okay.
Check over your exponents in the part in red, it is not E-28.
1.9878E-25/4.2E-7 = 4.7328E-19
(10x10E-3) / (4.7328E-19) = 2.1E16
Thank You!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
