What are the Forces and Acceleration of a Ball Subjected to Three Forces?
  • Thread starter Thread starter MaryJane101
    Force Physic
A 0.5 kg ball at rest is acted upon by three forces: F1 (5.0 N at 36.9 degrees above the horizontal), F2 (2.0 N to the left), and F3 (4.0 N downward). To analyze the situation, a free-body diagram should be drawn to illustrate the forces and their vector components. The net force's x- and y-components can be calculated using trigonometric functions based on the angles and magnitudes of the forces. Subsequently, the ball's acceleration can be determined from the net force, and the total distance traveled after 3.0 seconds can be calculated using kinematic equations. Understanding unit vectors and applying the correct mathematical principles is essential for solving the problem.
MaryJane101
A 0.5 kg ball initially at rest is subject to three forces:
1. F1 has a magnitude equal to 5.0 N and points 36.9 degrees above the horizontal direction (relative to the positive x direction),
2. F2 has a magnitude equal to 2.0 N and points to the left (negative x direction),
3. F3 has a magnitude equal to 4.0 N and points straight down (negative y direction).
Given these forces, answer the following questions:
a. Draw a free-body diagram showing the forces acting on the ball. Be sure to draw
vectors with the correct lengths. Determine the x- and y-components of each force
and label those values on your diagram.
b. Calculate the x- and y-components of the net force acting on the ball.
c. Calculate the x- and y-components of the ball’s acceleration.
d. Calculate the total distance traveled by the ball after 3.0 s.
At what point do you get stuck?
Are you familiar with unit vectors?
I don't even know where to begin this is all new to me
i got the free body drawing but how do i do part b c d ?
For part b, you'll need to apply trig functions (sin and cos) to the forces you drew, using the angle of each of the 3 forces.
Also, keep in mind that:
Horizontal forces (acting to the left or right) act in the +x or -x direction -- there is no y-component.
Vertical forces (up or down) act in the +y or -y direction -- there is no x-component.
Surely there is an example worked out in your textbook or class lecture notes?
