What Are the Dynamics of a Bicycle Wheel with External Forces?
  • Thread starter Thread starter icedcake
    Bicycle Physics
A bicycle traveling at a steady velocity of 4 m/s has wheels that rotate at approximately 127.4 rpm, calculated using the wheel's circumference. When a mosquito lands on the top of the wheel, the normal force it experiences is affected by centripetal acceleration, resulting in a force of mg - ma. The velocity of mud flying off the top of the wheel is twice the bicycle's speed, leading to a straightforward application of projectile motion to determine its descent time. The discussion also highlights the need to convert linear motion into circular motion to find angular deceleration when the bicycle stops. Overall, the dynamics of the bicycle wheel under external forces involve complex interactions between linear and rotational motion.
icedcake
A bicycle is traveling along a flat straight road with a steady
horizontal velocity of 4m/s.
Assume the front and rear wheels have a radius of 0.3m and they
do not slip on the road.
a. How many rpms (revolutions/minute) do the wheels make?[1]
-4m/s *60sec/1min = 240m/min
Circumference: 2pi*r= 0.6pi = 1.884 m/rev
240m/min divided by 1.884m/rev = 127.4rpm
im pretty sure that's right...
b. A mosquito of mass m lands on the top of the wheel as it is going down the
road. When it is on the top of the wheel, what is the normal force felt by the
mosquito. Neglect the force of the air.[1]
-N-mg=ma
-N=ma+mg
N= -(ma+mg) <--- NOT 100% SURE ITS RIGHT.
c. Suppose a piece of mud flies off the very top of the wheel. What is it velocity, Vx and Vy with respect to the ground? Note definition of x-y coordinates. [1]
I HAVE NO IDEA WHERE TO START!
d. How long will the mud take to reach the ground? [1]
THIS ONE EITHER...
e. If the bicycle stops using a constant breaking force over a distance of 10 m, what is the angular deceleration of the wheel?[1]
Welcome to PF!
(a) looks good.
(b) When the wheel is not turning the normal force holding the bug against the wheel is mg. When the bug is moving in circular motion on the wheel, it will feel less pressed against the wheel - as you do when riding in a car going fast over a hill. So it must be mg - ma, where a is the centripetal acceleration.
(c) As the wheel turns, its center is moving at 4 m/s with respect to the ground. The bottom of the wheel is not slipping on the ground, so its speed must be zero. The top of the wheel appears to be moving forward with respect to the rider so it must be going faster than 4 m/s. It turns out to be twice as fast.
(d) With the answer to (c) you can do this. Just projectile motion.
(e) Too bad they don't give the force; you will have an F in your answer.
Just convert the linear motion into circular motion. See http://hyperphysics.phy-astr.gsu.edu/hbase/rotq.html#drot for conversion formulas.
