Physics Homework about using Electricity to Heat Flowing Water
The discussion revolves around the design of an electric instantaneous water heater intended to heat 5.0 liters of water from 10.0 °C to 45.0 °C using electrical resistance. Participants are analyzing the calculations related to resistance and current required for the heating process, given a voltage of 230V.
  • Participants are examining the relationship between heat energy and electrical energy, questioning the appropriateness of using the same symbol for heat (Q) and charge. There is a focus on the specific heat capacity of water and the implications of the calculations presented by the original poster.
Several participants are providing feedback on the calculations and the use of equations, suggesting that the original poster may not fully understand the context of the formulas used. There is an ongoing exploration of the correct relationships between energy, current, and resistance in the context of heating water.
Participants note potential errors in unit usage and the need for clarity in the definitions of terms used in the calculations. There is also a mention of safety concerns regarding electrical current levels.
Detopall
New user has been reminded to show their work on schoolwork questions
This is a question of my Physics homework: Electricity
Q = c m ΔƟ
I = Q/t
R= U/I
This is the question: You want to make an electric instantaneous water heater in which 5.0 liters of water flows past a resistance per minute and heats water from 10.0 ° C to 45.0 ° C. Calculate the magnitude of the resistance to use and the amperage. The flow-through is connected to 230V
So: Given: 1min = 60sec = t// 5.0l = volume of water= 5kg = m // ΔT = 35°C // V = 230V //
Asked: R & I
Answer: Q = c . m . ΔT
Q = 4186 . 5 . 35
Q = 732550 J/kg . K
I = Q/ t
I = 732550/ 60
I = 12209.17 A
Hi @Detopall,
:welcome:
What have you tried so far to solve the problem?
Your "relevant equations" are all electrical. What about the heat?
Detopall said:
Q = c m ΔƟ
This looks pretty much like heat relation to temperature through mass and specific heat capacity. Using Q to denote both heat and charge is however ... questionable ... at best.
Thanks @Orodruin -- for the life of me, I couldn't decode that first equation (but I was starting with the "electrical" Q)... o0)
Yeah, right. Sorry. Like berkeman I just saw the Q's and thought, something about charge, irrelevant.
It's not a formula I've used for a long time (if ever?), whatever letters. I just remember it as the mechanical equivalent of heat is 4.2 J/cal. I never really think about water as having a specific heat capacity until it comes to the latent heat.
Asked: R & I
Q = 4186 . 5 . 35
Q = 732550 J/kg . K
I = Q/ t
I = 732550/ 60
I = 12209.17 A
I don't even need to continue. 10 mA is deadly.
I don't know what I did wrong. Can anybody help? Thanks.
... and more likely leads to serious errors when you just blindly insert heat instead of charge into I = Q/t.
  • Haha
Detopall said:
Q = 732550 J/kg . K
In addition to the above, this is also wrong. The units of heat is Joules. You have given the units of the specific heat ##c##.
But do you know what you did? (and understand it maybe?)
Little in your working shows what you are finding in the context of the question. You are substituting numbers into algebraic expressions and doing arithmetic calculations perfectly well. But why? What does it all mean? Don't use formulae (equations) blindly. Think what they mean.
The water heater needs to give energy to the water to heat it up.
So you've worked ot the amount of energy needed to heat 5l of water by 35 K. (You should sort out the units here as Orudruin says.)
That energy has to come from the resistor.
As Orudruin says, your formula ##I=\frac Q t ## does not clculate energy. It says current is charge / time
Do you know how to work out the power or energy given out by a resistor in an electric circuit?BTW "10 mA is deadly." I believe the deadly figure is over 30 mA. That's when ELCB's trip. But don't worry, you're going to need a lot more than that to heat this water. Just don't put your finger on the wires when it's switched on:smile:
23K
