Physics-Stable Equilibrium and Oscillations
The discussion revolves around a physics problem involving a one-dimensional force acting on an object, specifically focusing on stable equilibrium and oscillations. The force is defined as F(x)=(3.0N/sqrt(m))*sqrt(x)-(1.0N/m)x, and participants are tasked with finding the equilibrium position and the frequency of oscillations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of equilibrium positions, with some expressing confusion over differing results. Questions arise regarding the interpretation of units in the force equation, particularly the role of 'm'. There is also exploration of the derivative of the force function to determine stability.
Some participants have provided guidance on the interpretation of the force equation and the implications of the derivative for determining stable equilibrium. There is an ongoing exploration of the calculations for both parts of the problem, with some participants expressing uncertainty about their methods and results.
Participants are navigating potential misunderstandings regarding the units in the force equation and the implications for their calculations. There is a lack of consensus on the correct equilibrium positions, and some assumptions about the force function are being questioned.
smiles75
A one-dimensional force F(x)=(3.0N/sqrt(m))*sqrt(x)-(1.0N/m)x acts on an object of mass m = 2.57kg.
a Find the position x0 where the mass is at a stable equilibrium.
b Find the frequency of small oscillations around that equilibrium position. How does this compare to the
frequency if we were to simply ignore the rst term (the square root dependence) in the force?
F(x)=0
So for the first part i set F(x)=0 and i got x=0 and x=23.13 but then i did it again and got x=0 and x=64.274 I have noooo idea how they ended up that different. and I'm not even honestly sure how to start b. anything would be helpful.
You need to redo part a because both of your answers don't make sense. Note that the m in the first term is part of the units and stands for meters; it's not the mass.
(3.0N/m^1/2 )x^1/2 - (1.0N/m)x acts on an object of mass m = 2.57kg. <- that is my problem copied and pasted... so Newton/sqrt(meter) i don't get that :/
Vela's correct. Since F(x) is force, it has a unit of 1 Newton. For the function to equal that, m must be meters since if m is mass, x would become mass which x isn't according to the text. m must be meters for the units to make sense.
So, pretty much you're telling me my life got 10x easier? thank you haha. in that case... would i be correct in saying that it's at x=0 and x=9? and then take the derivative which would be...
F'(x)=(3/2)x^-1/2-1 so if i use 0 its undefined, so therefore 9 is stable. that's part A.
so F'(9)=-.5
and for part b would i just use... 1/(2pi)*sqrt(k/m) (where k=.5) which would equal... .0702hz? i hope my units are right... and then if the sqrt wasn't there, k=1 so it would be .0992hz. Please anyone, correct me if I'm wrong.
so F'(9)=-.5
F'(0) being undefined doesn't imply x=9 is stable. It's the fact that F'(9)<0 that tells you that's a stable equilibrium point.
I didn't check your actual numbers, but I can verify your method is correct.
