Piston effort=load due to gas alone?
  • Thread starter Thread starter ajayguhan
    Gas Piston
Piston effort during the stroke is influenced by both gas pressure and inertia force, as stated in the discussion. Inertia force is relevant even in non-inertial frames because it affects the overall dynamics of the system. Simply equating piston effort with gas force neglects the complexities of motion and energy transfer in the engine. The work done during the power stroke translates into kinetic energy, impacting not only the piston but also the entire drivetrain and vehicle. Understanding these forces is essential for accurate analysis of engine performance.
ajayguhan
In my book it is mentioned that piston effort along the line of stroke=(Force due to gas pressure)+(Inertia force)
why we have to consider inertia force when it is a imaginary force which is considered only during non inertial frame?
why we don't equate piston effort with gas force simple (neglecting friction) why we have to consider inertia force?
the work done during the power stroke is translated into motion energy whether that is just the piston / crank / clutch etc when idling, or including the remainder of the drive train and the vehicle itself when in gear.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
