Plane region in polar coordinates
Telemachus
Hi there. I must express the next region in polar coordinates:
\{x\in{R^2:x^2+y^2\leq{2y}}\}So, this is what I did to visualize the region:
Completing the square we get:
x^2+y^2-2y\leq{0}\Rightarrow{x^2+(y-1)^2\leq{1}}
Then, polar coordinates form:
f(x)=\begin{Bmatrix} x=\rho \cos\theta \\y=\rho \sin\theta \end{matrix}
So I got
\rho^2=2y\Rightarrow{\rho=\displaystyle\frac{2y}{\rho}}\Rightarrow{\rho=2\sin\theta}
f(x)=\begin{Bmatrix} x=2\sin\theta \cos\theta \\y=\sin^2\theta \end{matrix}
Now, how do I express the region with polar coordinates? this is the inside of the circle, I've just get the expression for the boundary. How do I include the inside of it?
Bye there. Thanks for posting.
Convert this inequality to polar form, which gives you r2 - 2rsin(theta) <= 0, or
r(r - 2sin(theta)) <= 0.
I believe this is equivalent to r <= 2sin(theta). (I'm being cautious here because I haven't thought through the ramifications of r being negative and r - 2sin(theta) being positive and vice-versa. It's much more straightforward if you're dealing with an equation.)
So I got
I think your set can be described this way: \{(r, \theta) | 0 \le r \le 2sin(\theta), 0 \le \theta \le \pi \}
Thank you Mark.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
