Prove A = √(2/L) using Integration - Step by Step Guide
  • Thread starter Thread starter danoonez
    Integration
The discussion focuses on proving that A = √(2/L) using integration techniques. The user begins by manipulating the integral of sin²(nπx/L) and applying u-substitution to simplify the calculation. After evaluating the definite integral and performing algebraic manipulations, the user arrives at the conclusion that A² = 2/L, leading to the final result A = √(2/L). Participants provide feedback on the clarity of the steps, particularly regarding the use of parentheses in the sine function, and confirm that the overall approach appears correct. The thread concludes with a positive acknowledgment of the user's work and suggestions for improvement.
danoonez
From
<br /> \int_{0}^{L} A^2 sin^2 \frac {n \pi x} {L} dx = 1<br />
show that
<br /> A = \sqrt {\frac {2} {L}<br />
Here's what I did:
First bring A^2 out so that I have:
<br /> A^2 \int_{0}^{L} sin^2 \frac {n \pi x} {L} dx = 1<br />
Then I use u subsitution for the integral:
<br /> \int sin^2 \frac {n \pi x} {L} dx<br />
equals:
<br /> \int \frac {L} {n \pi} sin^2 u du<br />
Pulling out the constants I get:
<br /> \frac {L} {n \pi} \int sin^2 u du<br />
Which, using an integral table, equals:
<br /> (\frac {L} {n \pi}) (\frac {1} {2} u - \frac {1} {4} sin 2u)<br />
Plugging u back in and putting in my limits of integration I get my definite integral:
<br /> (\frac {L} {n \pi}) \left[ \frac {n \pi x} {2L} - \frac {sin 2 n \pi x} {4 L} \right]_{0}^{L}<br />
Plugging this back into the original equation I get:
<br /> A^2 (\frac {L} {n \pi}) \left[ \frac {n \pi x} {2L} - \frac {sin 2 n \pi x} {4 L} \right]_{0}^{L} = 1<br />
Then solving for the limits of integration I get:
<br /> A^2 (\frac {L} {n \pi}) \left[ (\frac {n \pi L} {2L} - \frac {sin 2 n \pi L} {4 L}) - (0 - 0) \right] = 1<br />
Then doing some algebra I get:
<br /> A^2 (\frac {n \pi L^2} {2 L n \pi} - \frac {sin 2 n \pi L^2} {4 L n \pi}) = 1<br />
...then some scratch work...
<br /> sin \pi = 0<br />
...so...
<br /> (A^2) (\frac {n \pi L^2} {2 L n \pi}) = 1<br />
After more algebra I get:
<br /> (A^2) (\frac {L} {2}) = 1<br />
So then:
<br /> A^2 = \frac {2} {L}<br />
And finally:
Q.E.D.
How does it look.
Sorry if it seems messy; this was my first time using LaTex.
There's a step around plugging n*pi*x/L back in for u where inexplicably the L in n*pi*x/L was pulled out of the sine function. Was this a typo?
You should really put parentheses around the variables in the sine function, i.e.
<br /> \Big(\frac {L} {n \pi}\Big) \left[ \frac {n \pi x} {2L} - \frac {\sin (2 n \pi x/L)} {4} \right]_{0}^{L}<br />
Everything else looks OK.
Thank you. I will do that for the paper I hand in.
vsage: I can't tell which step you mean. Could you clarify? B/c it may not have been a typo.
Anybody else see any mistakes?
I was referring to what e(ho0n3 pointed out. You seem to account for the typo though later so it looks great to me.
Excellent. Thanks for looking.
