Plotting the radial wave function of Deuteron in a finite well
The discussion revolves around plotting the radial wave function of the deuteron within a finite potential well. Participants are exploring the numerical methods required to find solutions for the wave function in different regions and ensuring continuity at the boundary.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to implement a numerical solution using Python, questioning how to handle continuity at the boundary. Some participants suggest evaluating the wave function and its derivative at the boundary to ensure correctness, while others discuss the relationship between parameters k and κ derived from continuity conditions.
Participants are actively discussing the necessary steps to ensure the wave function is plotted correctly, with some guidance provided on evaluating the wave function and its derivative. There is an emphasis on the importance of continuity and the need for numerical root finding to determine parameters.
There are mentions of specific values for the potential and energy, as well as the need to normalize the wave function. The discussion includes considerations about the assumptions made in the numerical setup and the implications of continuity at the boundary.
TopologyisGeometry
Plot the wave function ##u(r)## as a function of ##r## from 0 to 10 fm. Since ##u##is not normalized, you won't need units on the y axis.
$$\frac{-\hbar^2}{2\mu}\frac{d^2u(r)}{dr^2}+V(r)u(r) = Eu(r)$$ Where $$V(r) = \begin{cases}-V_0 \quad r<R\\ 0\quad r>R\end{cases}$$ Which has the solutions previously found to be
$$u(r)=\begin{cases}A\sin(kr)\quad r<R\\ De^{-\kappa r}\qquad r>R\end{cases}$$
To plot ##u(r)## we need to find the solutions for each region. Which is in the relevant equations part. Now, I have to do this numerically. Using python 3.7 I made an ##u## which is filled with zeros and a for loop with if/elseif statement, basically telling it to plot values for whenever ##r<R## and ##r>R##. Here is the plot generated by my simple code
Due to continuity at $r=R$ they need to have the same value. Which makes me believe that this is a root finding problem, basically ##A\sin(kr)-De^{-\kappa r}=0## Now I don't know how to implement this onto my code, at first I thought make another elif statement for when ##r==R## to use the roots as the values, how would I go on about this problem? Have I forgotten something?
You have some prepping to do that it is better done with pencil and paper, not code. At ##r=R##, the wavefunction and its derivative must be continuous. This will give you a relation between ##k## and ##\kappa## which you will have to solve numerically (the root finding part) to find ##k## and ##\kappa## for an assumed numerical value of ##V_0.## Then you can write the unnormalized wavefunction in terms of ##A## or ##D## and plot.
I found that ##k\cot{kr} = -\kappa## which comes from the fact that we claim ##u(r)## to be continuous everywhere and it's derivate too, then I just divided to get rid of the coefficients, where ##k^2=2\mu(E+V0)/\hbar^2## and ##\kappa^2=2\mu E/\hbar^2## if that's what you're asking ##V0=35MeV## and I found that ##E=-2.223 MeV## This should be everything to plot this right?
Before plotting, I would evaluate ##u(r)## and its derivative at ##r=R## to make sure that I did not make any mistakes. Also, if you are not going to normalize ##u(r)##, be sure to use one of the continuity equations in order to write ##u(r)## in terms of single constant, ##A## or ##D##.
  • · Replies 30 ·
