Pointwise convergence and uniform convergence
complexnumber
Define the sequence \displaystyle f_n : [0,\infty) \to<br /> \left[0,\frac{\pi}{2}\right) by f_n(x) := \tan^{-1}(nx), x \geq<br /> 0.
Prove that f_n converges pointwise, but not uniformly on
[0,\infty).
Prove that f_n converges uniformly on [t, \infty) for t &gt;<br /> 0.
\displaystyle \lim_{n \to \infty} f_n(x) = \lim_{n \to \infty}<br /> \tan^{-1} (nx) = 0 for x = 0.
\displaystyle \lim_{n \to \infty} f_n(x) = \lim_{n \to \infty}<br /> \tan^{-1} (nx) = \frac{\pi}{2} for x \in (0, \infty).
Let \displaystyle f : [0, \infty) \to \left[0, \frac{\pi}{2}<br /> \right) be defined by
<br /> \begin{align*}<br /> f(x) = \left\{<br /> \begin{array}{ll}<br /> 0 &amp; \text{ if } x = 0 \\<br /> \dfrac{\pi}{2} &amp; \text{ if } x &gt; 0<br /> \end{array}<br /> \right.<br /> \end{align*}<br />
Therefore f_n converges pointwise to f.
Is function f correct? How can I prove the rest?
[0,\infty).
Yes, that is correct. Now, just observe that each function tan^{-1}(nx) is continuous for all x while f(x) is not continuous at x= 0. If convergence were uniform, the limit function would also be continuous.
Thanks. I found a theorem that says if f_n converges uniformly to f then f must be continuous. Is it enough to say that since f is
discontinuous at 0, f_n cannot converge uniformly to f on [0,<br /> \infty)?
Is the following correct for the second question?
For any \varepsilon &gt; 0 there must be an N \in \mathbb{N} such
that for all n &gt; N and for all x \in [t, \infty)
<br /> \begin{align*}<br /> \abs{\tan^{-1}(nx) - \frac{\pi}{2}} &lt;&amp; \varepsilon \\<br /> \frac{\pi}{2} - \tan^{-1}(nx) &lt; &amp; \varepsilon \\<br /> \frac{\pi}{2} - \varepsilon &lt; &amp; \tan^{-1}(nx) \\<br /> \tan \left(\frac{\pi}{2} - \varepsilon \right) &lt; &amp; nx \\<br /> \frac{\tan (\frac{\pi}{2} - \varepsilon)}{x} &lt; &amp; n<br /> \end{align*}<br />
Therefore choose \displaystyle N = \frac{\tan (\frac{\pi}{2} -<br /> \varepsilon)}{t}. Then for any x \in [t, \infty),
<br /> \begin{align*}<br /> \abs{f_n(x) - f(x)} = \abs{\tan^{-1}(nx) - \frac{\pi}{2}} \leq<br /> \varepsilon<br /> \end{align*}<br />
whenever n &gt; N. Hence f_n converges uniformly to f in [t,<br /> \infty).
Yes, this is sometimes called the Uniform Limit Theorem and is fine to use (The above poster mentioned it).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
