Poisson Probability Distribution Problem
The discussion revolves around applying the Poisson probability distribution to model structural loads over time, given a mean time of 0.4 years between occurrences. Participants clarify that the expected number of loads in a 4-year period can be calculated using the rate of 2.5 loads per year, leading to an expected value of 10 loads. For determining the probability of more than 13 loads occurring, the cumulative distribution function (CDF) approach is suggested, specifically calculating 1 minus the probability of 13 or fewer loads. Additionally, to find the time period for a probability of no loads occurring at most 0.3, participants discuss setting up the Poisson equation with the appropriate parameters. The conversation emphasizes understanding the underlying concepts rather than just obtaining answers.
Callix
An article suggests that a Poisson process can be used to represent the occurrence of structural loads over time. Suppose the mean time between occurrences of loads is 0.4 year.
a). How many loads can be expected to occur during a 4-year period?
b). What is the probability that more than 13 loads occur during a 4-year period?
c). How long must a time period be so that the probability of no loads occurring during that period is at most 0.3?
I tried setting up the equation as a Poisson probability distribution for a). as (e^(-0.4)*0.4^(4)) / (4!) but I wasn't sure if this was correct. I couldn't move on to b or c without knowing a. If anyone could help give me some direction with good details that would be appreciated! I want to be able to learn the material and reasoning, not simply obtain the answer.
Also, I apologize if this is not in the right category. I didn't see any homework-related sub-forums for probability and stats.
Thanks in advance!
Is a). actually just 4/0.4?
Thanks in advance!
Your ##\tau = 0.4## yr. is a time, not a rate. The parameter in the Poisson distribution is dimensionless:
\text{parameter} = \text{mean number} = \text{rate} \times \text{time}.
In your problem, the rate is ##\lambda = 1/\tau = 1/0.4 = 2.5## events per year.
Problems in probability and/or statistics are usually posted here or in the "Calculus and Beyond" forum, depending on the level of the question and the mathematical tools needed to deal with it. Occasionally they appear in the Elementary or Advanced Physics forums, especially if they have something to do with experimental error analysis or statistical mechanics and the like.
Ah, that makes sense, so in this case what is x? Or is x the value that I am solving for?
So far my equation is \frac{e^{-10}10^x}{x!}
Oh, so ##\mu## (aka ##2.5 \times 4##) is the expected value, so that should be the value that I'm looking for for a)?
There was no letter "x" in the above; there was the multiplication sign ##\times##. Sorry if that confused you.
I was referring to the equation that I made in the following post. But I realized that the value that I'm looking for is ##\mu## anyway, which if I'm understanding correctly, should be 10.
I'm confused about how to go about b). It gave me a table of CDF values listed for ##\mu## and x, so and it wants P(X>13). My logic is that that would simply sum to infinity with infinite terms, so I did 1-P(X≤13). Since the table is CDF, that would mean I simple take 1-P(13) wouldn't it?
Yes, that would be the way to do it.
Alright. And for C, do I just solve for ##\mu## from the Poisson equation? And then divide by the rate?
Hmm, or could I solve C using the CDF tables?
Callix said:
Alright. And for C, do I just solve for ##\mu##? And then divide by the rate?
Solve for ##\mu## how? What would be the equation you want to solve?
Well it tells me that the probability would be 0.3 so I was thinking I could set it up as
\frac{e^{-\mu}\mu^x}{x!}=0.3
But then again I don't have a specified x...
Oh wait x would just be 0 because it's referring to no loads
Yes, exactly.
I know this is a necropost, but just curious as to how the constant ##\lambda## is determined in real life.
It's the expected number of events in whatever the time interval happens to be.
And you use long-term data to compute it, e.g., the number of patients arriving at the emergency room?
I would think so -- the average number of patients arriving per day or month, or whatever.
Yes, thanks, I meant the average.
