Potential difference and electric fields
The discussion focuses on calculating the potential difference between two points on the x-axis given a non-uniform electric field described by E_x = (5 kN/C) x^3. The initial attempt at using V = -Ed for a uniform field yielded incorrect results, prompting a realization that the electric field is not constant. Participants suggest using the integral form of the potential difference, V_b - V_a = -∫ E·dl, to account for the variable electric field. The calculations reveal confusion regarding unit conversions, particularly between kN/C and volts, leading to further errors in the final answer. Ultimately, the discussion highlights the importance of correctly applying equations for non-uniform electric fields and ensuring proper unit conversions.
peaceandlove
An electric field is given by E_x = (5 kN/C) x^3. Find the potential difference between the points on the x-axis at x= 1 m and x = 5 m. Answer in units of kV.
V = -Ed
V1 = -5*10^6 N/C * 1 = -5*10^6 volts
V2 = -5*10^6 * 5 = -25*10^6 volts = -2.5*10^7 volts
V2 - V1 = -25*10^6 -(-5*10^6) = -20*10^6 = -2.0*10^4 kV
I also tried cubing x and got -6.2e+5 but that is also wrong.
V=-Ed only when E is uniform/constant along the length of d...is that the case here?
If not, you will need to use the more general equation:
V_b-V_a=-\int_a^b\vec{E}\cdot\vec{dl}
I would think that the x^3 would mean that E is not uniform/constant...
-5*10^6 times the integral of x^3 from 5 m to 1 m... which is the same as -5*10^6*[(1/4)x^4] from 5 m to 1 m... which is equal to -7.8*10^5.
Is that it?
Where is the 10^6 coming from?
I meant 10^4 since it's in kN/C, so the answer would be -7.8*10^3 kN?
That apparently isn't the answer... what did I do wrong?
1\,\mathrm{kN} = 10^3\,\mathrm{N}
and
1\,\mathrm{kV} = 10^3\,\mathrm{V}
Could it be that?
Oh wow... yet another stupid mistake. Thanks so much everyone!
