Finding Spring Constants: An Experiment
In summary: Look at this and let us know which curve it looks like if any;http://homepage.mac.com/phyzman/phyz/BOP/2-03SHM/G-Hooke.pdf In summary, the graph does not seem to follow the standard spring curve. It rises very steeply at the beginning and then levels off into a straight line.
||spoon||
228
Sorry i ditched the template but as this is an experimental question i wasnt sure that it was needed.
FOr Physics i am currently writing up an experiment which i had to do i class, the experiment was based upon finding te spring constants of springs by hanging masses on them and measuring the extension.
I had recorded the results is a table and am now graphingt them... however i was under the impresseion that the graph (force extension) should be a straight line (gradient giving spring constant) however mine is not.
My graphy begins with a very high gradient and then turns into a "straightish" line afterwards. Is this simply because te masses to begin with were too small to create a linear like extension of teh spring? or is there something wrong with my graph/prac?
Thanks for any help, and sorry for ditching the template, also9 sorry for the non technical vocab haha...
Cheers,
-Spoon
spoon,
what was the slope of the line (should be= -k) after things looked right to you, and what was the range of masses where it seemed to behave weirdly. Scan it if you can, otherwise the above should help.
hey thanks for the reply,
Im not sure what the actual slope is, i haven't checked the gradient yet lol, but its pretty damn high. Te range of masses were 0.1, 0.2, 0.3, 0.4, 0.5 and 1 Kg's
They seem to become linear after the first few masses, is that because the force is not great enough to extend the spring properly, and if so how do i overcome that obstacle when writing up my prac? do i just discount them?
Thanks,
-Spoon
Thanks,
-Spoon
no, never discount them. anomalous behavior is often where discoveries lie hidden--tho in this instance I'm doubtful anything revolutionary will emerge. Now you can attempt to explain them away with good reasoning, but I guess I still don't have a good sense of which data is the good data.
http://homepage.mac.com/phyzman/phyz/BOP/2-03SHM/G-Hooke.pdf [Broken]
hey, my graphs don't really look much like any of those ones.. for the singular springs it is almost like a log graph, as in it is stepp, sorry STEEP!, to begin with but then levels off into a straight line (which is what i wanted!)
I also had to springs set up in parallel, so te new gradient should hvae benn K1 + K2 = new K, however i got a graph which slightly resembled the rubber graph which you supplied (thanks for that)
Im not sure how u attach documents and so on, if someone could explain this i have all the relevant information in an excel document.
Thanks again,
-Spoon
well from my reading Hookean is only relevant over a narrow range of displacement, it by flat you mean a horizontal line, I would say at this point you're out of the zone and the Steep data was the good stuff. assuming you're plotting mass on y and displacement on x
i never said taht the graph was flat, i said it went into a straight line, or at least "straightish".
I don't really know what is going on with it but it is my suspiscion that the masses i used to begin with i.i the 0.1's and 0.2's were not massive enough, and thus did not apply a high enough force on the spring to get the actual spring constant, instead the spring was barely stretched and i measured that small distance?
is this correct?
who knows? springs tend to be more linear under small displacements, and unless you have really small weights for the spring constant in question, or poor resolution, or both... its just crappy science,
1. How do I determine the spring constant using this experiment?
In this experiment, the spring constant can be determined by plotting the force applied to the spring versus the displacement of the spring. The slope of the resulting line on the graph will equal the spring constant.
2. What equipment do I need for this experiment?
To conduct this experiment, you will need a spring, a ruler or measuring tape, a weight or mass, and a support structure for the spring (such as a clamp or stand).
3. Can this experiment be used to find the spring constant of any type of spring?
Yes, this experiment can be used to find the spring constant of any type of spring as long as the spring is linear (obeys Hooke's law) and has a known mass and length.
4. What are some potential sources of error in this experiment?
Potential sources of error in this experiment include inaccurate measurements of the force applied and the displacement of the spring, as well as external factors such as air resistance or friction which may affect the results.
5. How many trials should I conduct in this experiment to ensure accuracy?
It is recommended to conduct at least three trials to ensure accuracy in this experiment. The average of the three trials can be taken to minimize the effects of any outliers or errors in individual trials.
