Pressure and Flow in a pipeline
  • Thread starter Thread starter Anika
    Flow Pressure
To calculate the flow rate in a 4-inch pipe with a starting pressure of 4 bar, it's essential to know the downstream pressure and the fluid's characteristics. The pressure must drop from 4 bar to atmospheric pressure, accounting for static losses due to elevation changes and dynamic losses from friction within the pipe. The Bernoulli equation can be modified to include friction losses, which are affected by flow rate and pipe configuration. As flow increases, pressure loss per foot of pipe also increases, creating a balance between flow rate and energy dissipation. Understanding these principles, including the Darcy-Weisbach equation, is crucial for accurate flow rate calculations.
Anika
I have a 4inch pipe and I know the pressure at the start of the pipe is 4 bar. How do you calculate the flow rate?
You're going to need to know something about the pressure in the pipe downstream. It also makes a difference what is flowing within the pipe.
Thank you. That is what I thought. I know it is water and that the pipe is connected to a 4bar line that supplies the water to this pipe system. The tie-in between the two lines is at a height of 4m.
Still not enough information.
Look, you could take an isolated pipe and pressurize it to 4 bar. There would be no flow, but the pressure inside the pipe would still be 4 bar.
If you are not familiar with the Bernoulli equation, perhaps this will help:
http://www.princeton.edu/~asmits/Bicycle_web/Bernoulli.html
Because this is water in a pipe, there will be friction, which the Bernoulli equation can be modified to include.
Short answer:
Unless the water is flowing into a pressurized container, it will have to discharge at atmospheric pressure. This means that between the water main (@ 4bar gage) and the outlet (atm), the liquid will have to lose 4 bar of pressure. It can lose the pressure in two ways. Losses due to static pressure loss from elevation change (outlet is higher in elevation than inlet) and dynamic pressure losses due to friction (from the water flowing through the pipe, through valves, filters, etc).
You can easily determine the static loss expected by looking at the elevation difference between inlet and outlet.
The friction loss calculation is a bit more involved, but basically: a pipe of a given material will experience a certain amount of non-reversible energy loss (realized by reduced pressure) for a given flow rate. This is true of fittings, valves, filters, elbows, etc. It's a balancing act. More flow means more pressure loss per foot of pipe. Less flow means less losses. Your flow rate is determined by the configuration of your system and how much water needs to flow through your pipes in order dissipate enough energy that the liquid leaves the system at atmospheric pressure.
Check out the Darcy Weisbach equation and all the stuff that goes along with it: http://www.engineeringtoolbox.com/darcy-weisbach-equation-d_646.html
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
