Pressure and Lift around a Wing
In summary: I remember seeing an experiment where a toy helicoptor inside a box begins to hover within the box. ...The toy helicopter does not generate lift because it does not have a suitable airfoil shape. It uses the same lift principle as a real helicopter, which is that the air flowing over the wings is deflected downward.I remember seeing an experiment where a toy helicoptor inside a box begins to hover within the box. ...The toy helicopter does not generate lift because it does not have a suitable airfoil shape. It uses the same lift principle as a real helicopter, which is that the air flowing over the wings is deflected downward.
fog37
1,568
108
Hello everyone,
I am pondering on the airflow around a wing:
When air flows over a wing, part of the air goes below the wing and part over the wing. Even when the air is moving, the pressure at a point in space is always isotropic. The pressure on top of the wing is slightly lower than than the free stream pressure. This pressure distribution produces a net force ##L _{top} ## on top of the wing directed downward. The pressure at the bottom of the wing is slightly larger than the free stream pressure farther away from the wing and produces a net lift force ##L _{bottom}##. The difference between these two forces, one pointing down and one pointing up, produces the overall lift force ##L_{total}= L _{top} - L_{bottom}## directed upward.
Does the static air located far above the wing rush toward the top of wing since it is at a higher pressure than the air closer to the wing? Also, the higher pressure air below the wing should push both on the bottom surface of the wing and also on the air farther below the wing. Is that what happens?
Thanks!
The airflow over the wind does get drawn downward. The net result is that the airflow gets diverted downward. This can be looked at as essential for the lift force on the wing. They are equal and opposite forces and reactions -- the airflow is diverted down and the wing is pushed up.
Yes.
Thanks a lot! This is how I envision it:
It is clear, from Bernoulli's equation, that fast moving air has a lower isotropic pressure than slower moving air. That said, I am not clear why from a molecular standpoint? Does anyone have a clear interpretation?
Thanks. I read that. I will read again.
Likes berkeman
Good. You should be aware that any simple answer to your question is over-simplified and will have to be discarded if you get deeper into the subject. The only real way to calculate lift is to apply Computational Fluid Dynamics (CFD), which traces tiny bits of air around the wing while calculating all the pressures and forces on it. Even that is very limited. Wind tunnel tests are done to verify and modify the CFD results to get an aerodynamic model. The flight tests are done in a careful sequence to make sure that flight results and aerodynamic model agree before more dangerous flights are attempted.
You are right. I don't want to look to much into it. I am just trying to grasp some qualitative understanding of the situation.
Thanks.
fog37 said:
I am just trying to grasp some qualitative understanding of the situation..
The shape of the wing forces air to go 'down', so therefore the wing obtains a force going 'up' (lift).
Likes sophiecentaur
[Mod Note:]
A severely wrong post and several responses were deleted.
Also, let's please keep this focused on the OP's questions and perhaps most importantly respect the OP's request to keep this as basic as possible. Not every discussion about how a car is propelled (for example) needs to get into the thermodynamics of the Otto cycle.
Thread re-opened.
Likes sophiecentaur
It amazes me that this inescapable fact seems to be accepted in discussions about a helicopter rotor but not accepted for a wing traveling in a straight line. The details of how the downward motion of air is achieved is very complicated and, as has been pointed out, there are many different levels for the analysis. You don't need an aerofoil to produce lift but it's just a good design which involves relatively little drag.
Likes rootone and FactChecker
That's an interesting point. I suspect that the helicopter version is accepted in an over-simplified form as though its blades operate like a screw digging into the air rather than as wings with a profile like an airplane wing. (Many early attempts at flight made that mistake.)
I remember seeing an experiment where a toy helicoptor inside a box begins to hover within the box. The weight of the box remains identical to the weight when the helicoptor just sat on the floor with no blade rotation. So obviously the weight of the hovering helicoptor was transferred by the air downdraft to the floor. I wonder if an equivalent experiment can be done with a model airplane. I think that it would be much more difficult to set up in such a convincing way.
I would be surprised (very) at an experiment that could show Newton's Laws of motion don't apply.
Sorry for the confusion. (I believe in Newton's laws as much as you do.) The example of a hovering helecopter, only supported by air is relatively simple. But it would be hard to keep a wing in place in a wind tunnel without some supports that complicate the logic of the conclusion.
I was not disagreeing with you. What you describe is supporting Newton. :smile:
A wind tunnel would need to be designed from scratch with facilities for measuring its weight. A lot of trouble to prove what can be proved in other, easier ways.
For the purposes of your demonstration, what would be wrong with using a 2-d wing section supported by the sides of the wind tunnel?
The point is to show that the force of the air on the bottom of the box is exactly the same as the weight of the plane that is floating above. Any support and forces from it can be all accounted for, but it is not as clear a demonstration. The hovering helicopter which requires no attachments is ideal.
I am confused as to the point of this demonstration.
The plane is floating, so it follows that the downward force exerted by the plane is equal to its weight.
Why is it also necessary to demonstrate that the box enclosing the plane weighs the same whether the plane is floating or parked?
I'm afraid that I have diverted this thread too much. I just thought that the helicopter demonstration was such a good demonstration of "equal and opposite" in the aerodynamics context that it impressed me at the time. It wouldn't bother me if a monitor cut this out.
A narrow wind tunnel would be cheaper but there would be an issue with the interaction of the air flow and the sides / corners. The way N3 applies to these things is easily observed when you see the result of turning a heavy boat with a rudder. There is a visible disturbance of the water, way into the inside of the curve, with eddies moving inwards by a significant distance. That 'Momentum' is very visible, unlike the air that trails behind an aircraft.
I didn't say a "narrow" wind tunnel, I said a 2-d wing section — you have a relatively wide section and tunnel where the wing does not vary across the flow, and then you try to observe a 2-d flow away from the edges of the tunnel.
The streamlines are typical made more visible by injecting smoke or other tracers.
Oh yes. A misunderstanding. I expect most basic wing design and optimisation can be done with 2D sections. What happens at the ends can be very relevant though - as demonstrated by all these fancy new wings on passenger jets with the clever bits on the tips. (You can tell I am speaking not as an aerodynamicist)
But, of course, the streamlines would need a massive space to develop fully and to reveal a downward motion that is actually providing the N3 lift.
Correct. Using the air as a frame of reference (instead of the wing), the air accelerates downwards and it's pressure decreases as it approaches the plane swept out by a wing as a wing passes through the air. As the air passes through the plane swept out by a wing, there's an increase in pressure with little or no increase in speed. This pressure jump corresponds to the energy added to the air by a wing passing through a volume of air. With this increase in pressure, the air continues to accelerate downwards as it's pressure returns to ambient. The speed of the air when it's pressure returns to ambient is called the "exit velocity". Nasa has an article on propellers that explains this, although the diagrams ignore the viscous interaction with the surrounding air. Note that from the air's frame of reference, Bernoulli is violated as the air flows through the plane swept out by the wing, because work is performed by the wing by increasing it's pressure. The Nasa article mentions this.
https://www.grc.nasa.gov/www/k-12/airplane/propanl.html
So, inside a fluid is moving in the direction ##x## at uniform speed v, a fluid particle (small blob of fluid composed of many molecules) will feel an isotropic pressure ##p_0## from all the other fluid particles around it. Neglecting depth effect on pressure, if the fluid particle is brought to rest (at a stagnation point), the new pressure the particle would experience is increased to ##p_0+\rho \frac {v^2} {2}##. But without bringing the fluid parcel to rest, the pressure will only be and remain ##p_0## and be isotropic and the fact that the fluid is moving at speed ##v## in the x direction will not show it effect.
Does that mean that the pressure ##p_0## would be the same as when the fluid is at rest even if the fluid is actually moving unless we bring it to a stop?
Your nomenclature is somewhat nonstandard. Let me try rewriting this. Let's assume for a moment that a given flow is steady, inviscid, and adiabatic. A given fluid element moving with velocity ##V## in an incompressible flow will have total (or stagnation) pressure
[tex]p_0 = p + \dfrac{1}{2}\rho V^2.[/tex]
We typically call ##p_0## (sometimes written ##p_t##) the total or stagnation pressure, which is the pressure that would be felt if the flow was isentropically (i.e. no heat added, not energy dissipated) brought to rest. ##p## is the static pressure and is what is felt by a surface immersed in said fluid whether it is moving or not. The ##V^2## term is dynamic pressure and isn't truly a pressure but a kinetic energy term. The whole statement really amounts to a conservation of energy statement. In an isentropic flow, ##p_0## is a constant, so if you bring the velocity to zero, ##p = p_0## and the surface at the stagnation point feels that pressure. Anywhere else in the flow, and the pressure felt by the surface is ##p##, which is some fraction of ##p_0## based on the value of the dynamic pressure.
The static pressure (sometimes called thermodynamic pressure) is always isotropic. It acts equally in all directions. This is universally true of static/thermodynamic pressure. Now, if you are talking about the actual stress tensor in the fluid, that is not necessarily isotropic in all cases, but the pressure itself is.
Thanks boneh3ad.
I "think" we are on the same page. There is one and only one pressure which is always isotropic, from the standpoint of a fluid parcel. In a fluid at rest (hydrostatics), the pressure would be ##p## and only vary with depth. If the fluid was in motion, the fluid parcel would still feel the same pressure ##p## unless we brought the flow to a stop. At the stopping point (stagnation point) the pressure, still isotropic, would become ##p_0## and be larger since the momentum of the flow is now converted in extra pressure. What has always confused me was the fact that, either at rest or in motion, the fluid parcel would apparently feel the same pressure, the thermodynamic pressure, unless it was brought to rest.
Bernoulli's equation is often read as the local isotropic pressure as being different for different flow speeds. that does not seem to agree with what I say above. If the fluid is moving fast or slow, the pressure a parcel exerts on other parcels and the pressure the parcels exert on is just ##p_0## since the pressure increase only derives from converting the momentum into force.
That said, I see how in a tube narrowing, based on Bernoulli's equation, there must be a gradient of pressure to accelerate the fluid (faster in the narrowing). So, in that case, the pressure ##p## seems to be different for different speeds...
Correct. The assumption is no external forces that could change the total energy within the tube, so total energy: pressure x volume + kinetic energy is constant. For the transition into a narrower tube, some of the pressure energy is converted into kinetic energy, resulting in a lower pressure ##p## in the faster moving fluid.
Since the title of this thread is about wings and lift, the situation changes depending on the frame of reference. From the wings frame of reference, assuming an idealized wing, the flow is diverted with no change in speed (no change in total kinetic energy). From the air's frame of reference, as a wing travels through a volume of air, it accelerates the air downwards, increasing it's energy. As posted earlier, most of this increase in energy is a pressure jump that occurs as the air crosses through the path swept out by a wing passing through a volume of air.
Thanks rcgldr. I fully agree with your comments. But think of these scenarios: two cylindrical pipes of the same diameter ##D## and uniform cross-section (no narrowings or expansions). The same fluid flows at speed ##V_1## inside the pipe. The other fluid flows at ##V_2 > V_1##. Without bringing the fluid to rest and creating a stagnation point, wouldn't the isotropic pressure felt by a fluid parcel be the same in both cases even if the fluid speeds are the different? the speed difference will only become apparent if the fluids are stopped. Is there any truth in what I am saying?
I don't understand your point here. You have two independent flows, each of which can have a different static pressure and different dynamic pressure. You can define the situation so that the two flows have the same static pressure. The velocities are relative to some frame of reference. Consider the case of two planes moving at different speeds and the pressures sensed inside each planes pitot tube.
rcgldr, Sorry if I am not clear. Let me try one more last time.
Consider two vertical pipes with fluid flowing from left to right at uniform but different speeds ##V_1## and ##V_2##. I think these are possible and feasible scenarios.
Even if the two blue fluid parcels travel to the right but at different speeds, I am arguing that the isotropic pressure at those two identical points in the fluid is the same regardless of the difference in speed. Of course, different fluid parcels will occupy that position as time goes on. Is that incorrect?
If we brought the bottom parcel traveling at speed ##V_2## to rest, the pressure at the stagnation point would higher compared to the case above with speed ##V_1##.
That's because what you wrote above is incorrect. The static pressure absolutely does change when velocity changes. The total pressure represents the total energy per unit volume in the flow. If the fkownlocally accelerates, it's kinetic energy per unit volume (dynamic pressure) increases and its static pressure has a corresponding decrease.
Well that's not true. There is energy dissipated by the forces causing drag on the wing, meaning the total pool of energy absolutely decreases in either frame of reference.
You are neglecting the fact that each pipe can have a different toal pressure since they are in no way related other than being in the same problem. There's nothing we can say about the pressure in either pipe other than the fact that it will be isotropic.
  • #31
For my concept of an idealized wing, there is no drag. In the air's frame of reference, and using a glider in a steady descent to simplify things, then the energy of the air is increased, and the gravitational potential energy of the glider is decreased.
  • #32
Can drag be eliminated, ever?
  • #33
I don't think it can. Even if skin friction is ignored, the same pressure forces that produce lift produce induced drag.
https://en.m.wikipedia.org/wiki/Lift-induced_drag
Likes boneh3ad
  • #34
Not in a real world situation, which was the point of using an idealized wing to focus on just the diversion of flow. High end cross country gliders, like the Nimbus-4 come close. At 1500 pounds (including pilot), it has about a 60 to 1 glide ratio at somewhat over 60 mph. Assuming it is 60 to 1 at 60 mph, that's 60 mph forward speed with a 1 mph descent rate, which translates into 4 hp.
boneh3ad's post mentions the fact that drag dissipates energy (it converts the energy into heat). This is different than induced drag which is related to diversion of flow. For an "idealized" wing, the flow is diverted, but the speed is not changed. The components of velocity are changed, the horizontal component is decreased, and the vertical component is increased (from zero to some non-zero "exit" velocity). The aerodynamic force vector points upwards (lift) and a bit backwards (induced drag). The point here is that lift induced drag is related to the diversion of flow, not dissipation of mechanical energy being converted into heat, such as friction or viscous related drag.
  • #35
I can see how the 'in vacuo' approach to this whole business leads to arguments and confusion. How is the paradox explained that air has to be deflected (along with its KE) in order to follow N3, yet no Energy is lost in the process
  • Classical Physics
  • Mechanical Engineering
  • Mechanics
