How to Find Air Pressure in a Vessel Being Evacuated Over Time?
The discussion focuses on finding the air pressure in a vessel being evacuated over time, assuming an isothermal process. The initial pressure is denoted as po, with a constant evacuation rate C. The ideal gas equation is applied, leading to a differential equation that incorporates the rate of change of moles, dn/dt, which is negative due to the decreasing amount of gas. The correct formulation results in dp/dt = -PC/V, allowing for the calculation of pressure as a function of time. The solution is confirmed as accurate by participants in the discussion.
Saitama
Find the pressure of air in a vessel being evacuated as a function of evacuation time t. The vessel volume is V, the initial pressure is po. The process is assumed to be isothermal, and the evacuation rate equal to C and independent of pressure.
Note: The evacuation rate is the gas volume being evacuated per unit time, with that volume being measured under the gas pressure attained by that moment.
By the ideal gas equation,
pV=nRT
\frac{dp}{dt}=\frac{RT}{V}\frac{dn}{dt}
\frac{dp}{dt}=\frac{RT}{MV}\frac{dm}{dt}
where m is the mass of gas in the vessel and M is the molar mass of the gas.
Now i am stuck here, i don't know what to do next.
The process removes C units of volume of gas each second. If C units of volume are removed at pressure P and temperature T, how many moles are removed?
##\frac{PC}{RT}## ?
Pranav-Arora said:
##\frac{PC}{RT}## ?
Yes. Use this for dn/dt in your diff eq. [Edit: think about the sign of dn/dt]
\frac{dn}{dt}=-\frac{PC}{RT}
(Negative sign because the moles keeps on decreasing)
\frac{dp}{dt}=\frac{RT}{V}\frac{-PC}{RT}
\frac{dp}{dt}=\frac{-PC}{V}
Solving this, i get the right answer. Thanks a lot TSny! :smile:
