Pressure in Fluids: Conceptual Q & Maths Explained
  • Thread starter Thread starter crazy student
    Fluids Pressure
The discussion centers on the nature of pressure in fluids, particularly whether pressure is equal in all directions at a given depth. It is established that while pressure varies with height, the isotropy condition indicates that pressure should be the same in all directions at a point in a fluid at rest. This isotropic behavior arises from the kinetic energy distribution of fluid particles, which leads to equal pressure exerted in all directions. The conversation emphasizes that pressure is a scalar quantity and does not have directional properties like horizontal or vertical pressure. Ultimately, the equality of pressure in all directions is a fundamental characteristic of fluids, supported by both experimental observations and theoretical frameworks.
crazy student
I have a conceptual question about fluid...
we derive the equations about pressure in fluid by considering the mass above a particular point in fluid.
and for fluid at rest, the pressure above equals pressure from below.
how about on the perpendicular plane? is the pressure on the sides equal to pressure from above and below also?
my textbook says that 'At any point in a fluid at rest, the pressure is the same in all directions at a given depth',
is it an experimental statement or can it be shown mathematically?
If the pressure was not the same on either side of your fluid "element", there would be an unbalanced (net) lateral force on it, and it would move. The fact that we're considering hydrostatics means that must not happen.
To tackle this specific point, the whole point of the analysis was to show that pressure varies only with height. Since "above", "below", and "on the sides", generally describes three different heights, I don't see why the pressure would be the same at any of these points. For instance, you already know that the pressure below is higher than the pressure above, so how could the pressure on the sides be equal to the pressure "above and below"?!
But this is not sufficient to demonstrate that the horizontal pressure is the same as the vertical pressure. It only requires that horizontal pressure be the same in two sets of opposite directions and that vertical pressure be the same in both directions, not that they all be equal. The equality in all directions is unique to fluids. It is certainly not a requirement for solids.
I think you would have to look microscopically at the nature of fluids and get into the statistical mechanics of ensembles of particles to justify the statement of equal pressure in all directions. The pressure is the same in all directions because the kinetic energy distribution of the particles in a fluid is isotropic. The interaction of an infinitesimal volume of fluid with its surroundings will involve collisions of energetic particles with isotropic momentum distribution, etc etc etc
Pressure is a scalar. It has no direction, so there's no such things as horizontal and vertical pressure.
OldeDan is correct, what we have to show is that the scalar pressure, p=p(x,y,z,t)
at most, and not p(x,y,z,t,\vec{n}) where \vec{n} is the normal to the surface element we're looking at, at the point (x,y,z) at time t
This is not completely trivial, since forces would balance on either side of a surface, as long as p were an even function of \vec{n}
Since, then:
p(\vec{x},t,\vec{n})\vec{n}dA+p(\vec{x},t,-\vec{n})(-\vec{n})dA=\vec{0}
The condition that the pressure does not depend on the orientation of the local surface element is called the isotropy condition.
