Which Liquid Exerts the Greatest Pressure at the Base of a Cylinder?
  • Thread starter Thread starter Herwin
    Pressure
The discussion centers on determining which liquid exerts the greatest pressure at the base of a cylinder, given varying heights, densities, and base areas. Participants emphasize the need to apply the fundamental principle that pressure in a fluid is determined by the product of height and density, regardless of base area. A specific equation for calculating pressure is suggested but not explicitly stated in the conversation. The importance of showing an attempt at solving the problem before seeking help is also highlighted. Overall, the conversation stresses understanding fluid pressure concepts to arrive at the correct answer.
Herwin
Which of the following liquids exerts the greatest pressure on the base container?
Height; Density; Area of Base
A.10cm 1000kg m^-3 20cm^2
B.10cm 1500kg m^-3 20cm^2
C.20cm 1800km m^-3 12cm^2
D.20cm. 1600kg m^-3 7cm^2
The liquid is contained in a cylinder.
Please answer with explanation.
Herwin, it's up to you to solve this problem. Those are the Rules at PF.
My apologise, I don't understand what do you mean by its up to me to solve these problems. Because there are different variations of their respective height,density, and area. I think there must be an specific answer for this question because it's a question from my test which is either a b c or d
This is plain English. What it says it what it means.
According to the Rules of PF (you did read those, didn't you?), posters to the HW forums must show an attempt at solution in order to receive help.
If you have studied what determines the pressure in a fluid at a given depth, then the answer to this question is quite simple to determine.
The only thing simpler is writing your name on the test paper. :wink:
If you had used the required homework template, you would have been prompted for an equation that might apply to your problem. What equation might that be?
Chet
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
