Solve Pressure Problem: Upward Force for Ocean Hatch
  • Thread starter Thread starter tommyhakinen
    Pressure
To determine the upward force required to open a hatch of area 0.75 m² at a depth of 30 meters in the ocean, the internal pressure of 1 atmosphere must be considered alongside the pressure exerted by the water. The relevant equation combines atmospheric pressure and hydrostatic pressure: P = Patm + ρgh. The upward force can then be calculated using F = P*A, where P is the total pressure acting on the hatch. The approach discussed in the thread is correct for solving the problem.
tommyhakinen
A submersible with internal pressure of 1 atmosphere is at a depth of 30 meter below the surface of the ocean. At this depth, what is the upward force required to open a hatch of area 0.75 m2. Assume density of sea water is 1030 kg/m3.
P = Patm + ρgh
F = P*A
Do I have to add the atmospheric pressure on the surface of the ocean? I have this equation : Patm + ρgh = Pinternal + P2
then F = P2 * A.
is this approach right?
Yes, looks good.
p.s. Welcome to PF.
Thank you..
