Pressure required to lift a weight
The buoyant weight in the hydraulic setup does increase the pressure at the bottom of the tank due to the additional water displacement caused by the weight, which raises the water level. The pressure can be calculated using the formula p = ρgd, where ρ is the water density, g is gravity, and d is the new depth after accounting for the buoyant weight. To lift the 10 kg weight through the Ø10mm pipe, the pressure must be sufficient to overcome the combined weight of the water and the buoyant weight. Elevating the feed tank will increase the pressure available, allowing for a smaller tank to be used. Calculations for the pressure in the u-bend must consider the height and direction changes, along with the total weight being lifted.
benb4ll
Assume all dims in millimeters and kilos and I am working on a hydraulic set up
I have a cylinder Ø200mm diameter x 400 high, it has a hole in the middle Ø10mm going into a capped Ø10mm pipe. The cylinder is filled with water up to 300mm high. There is a bouyant weight that floats on top of the water that weighs 10Kg.
Q1. Firstly, does this bouyant weight increase the pressure at the bottom of the tank (at the Ø10mm cap)? If so, what is the pressure difference if the weight was not there? Or because thre weight floats on top, is the pressure difference negligible?
Q2. If the water was emptied out what pressure/weight/volume of water would be needed in order to fill the cylinder back up with the 10KG weight sitting over the Ø10mm pipe? Assuming that water cannot pass around the weight. ALso, if the tank of water that is being used to fill the cylinder was elevated, would this help in using a smaller tank so the pressure increases?
Any help appreciated. Its been many many moons since I did any physics, hydraulics calculations...
TIA
Ben
At any given point inside the water at a depth d, the pressure is simply the weight of the column of water at that point, so, if you take gravity, the volume of water, consider its density, divide that weight by the cross sectional area at that depth...you end up with pressure p = ρgd, where ρ (rho) is water density, g is gravity and d is the depth you are at.
So, does the 10kg floating object increases the pressure? Yes, because it will sink a bit into the water, displacing a certain amount of water where the object itself is and rising the water level in the tank...take this new 'depth' to the bottom of the tank, and you have a new higher pressure.
Or, take the weight of all the water, add 10 kg, divide that force by the cross-sectional area at the bottom of the tank and that is your new pressure...basically, the bottom of the tank needs to carry the weight of everything on top of it...right?
2.-
Again, force is pressure times area and so, if you need to lift a weight of 10kg through a 10mm diameter pipe...you need to calculate the pressure needed so that when multiplied with that cross sectional area...you get 10 kg.
Yes, rising the tank will increase the pressure available.
OK,
So I have worked out a figure for the pressure. (based on the volume of water being 0.003534m3
p = 0.003534m3
therefore P= 0.003534 x 9.81 x 200mm (depth)
therefore P= 6.9337kg/m3
But if i use the other calc taking the weight of water (0.003534) +10Kg / 0.785 (cross sec area of tube @ 10mm) = 12.743Kg/m3
So I am confused to the different results?#?
cross -sectional area at the bottom = ∏r2
where r = 100 mm = 0.1 m
volume of water is cross - sectional area times height = ∏ r2 h
where h = 300 mm = 0.3 m
weight of such volume of water is density times volume = ρ x volume
where ρ = 1000 kg / m3
Double check your numbers
OK, I have worked out that the weight of the water is 9.426Kg in a tank that holds Ø0.2 of water x 0.3m high.
I have tank 1, Ø10mm pipe on a u bend going into another tank (tank2) at the other end of the u bend.
so how do I work out and include the acting pressure of what is needed in the u bend in order to lift the weight.
so.. the u bend I/D is 10mm it goes down 0.1m, goes to the right 90° 0.3m, goes up 90° 0.1m into the tank2.
I guess the weight required to lift the weight in tank 1 directly must be 10KG + 9.426.
But, how do we include the reacting pressure from the u bend and also is there a formula to work out how much pressure increases when you elevate the feed tank 2?
TIA
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
