Principle of equal transit times
  • Thread starter Thread starter Munch_E
    Principle Transit
The principle of equal transit times suggests that two particles of air leaving the same point will arrive at the same point simultaneously, which is a key assumption in the Bernoulli principle's explanation of lift. However, this principle is criticized as overly simplistic and unrealistic, as lift is more accurately explained through circulation and vortex dynamics. The discussion highlights that a tangential discontinuity occurs when flow characteristics change abruptly, indicating that the flow behind an airfoil is not irrotational. Consequently, the Bernoulli principle does not apply in this scenario due to the presence of vortices, as explained by Kelvin's Theorem. Understanding these complexities is essential for a more accurate explanation of lift in fluid dynamics.
Munch_E
How does the principle of equal transit times works?
the Bernoulli principle explains lift by high speed = low pressure but these relays on the fact that two particles of air living the same point A will arrive at the same point B at the same time and this is explained by the "principle of equal transit times" my question is what is this principle and how does it work? :confused:
I think that the lift explanation provided by Bernoulli principle is a little bit primary and not realistic. The lift forces exerted on an airfoil comes generally from circulation considerations, more than that simplistic explanation.
About that principle you mentioned, think of the next experiment. Imagine a vertical front of fluid moving through the airfoil. All the particles have to reach simultaneusly the end of the airfoil because if not there would be a tangential discontinuity.
In fact this discontinuty exists, and it's a vortex behind the airfoil generated by the Kelvin Theorem. So that, we come up with the conclusion that such time principle is unreal and do not waste much time thinking on such a simplistic descriptions when you try to achieve an explanation about lift.
first of all I thank you for your quick and extensive answer.
but I didn't quite understand what "tangential discontinuity" means.
(english in not my native tounge =\ )
A tangential discontinuity is a discontinuity of some fluid maginitude such as velocity, density or pressure. I mean if the flow goes on x direction, a tangential discontinuity is a line such that flow magnitudes vary suddenly through "y" direction. The problem here is that just behind the airfoil the flow is no longer irrotational. Therefore, the Bernoulli principle is not applicable. A vortex is generated behind the airfoil, in part because of the principle you mentioned is not yielded, and because of the Kelvin's Theorem.
English is not my native language too. :smile:
thank's :biggrin:
now I've got it.
and by the way your english is very good :smile:
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
