How Do Two Superposed Waves Result in Points of Zero Displacement?
The discussion focuses on deriving the resultant displacement from two superposed waves, given by the equations y1=Ysin(kx-wt) and y2=Ysin(kx+wt). The resultant displacement is expressed as y=2Ysin(kx)cos(-wt). To find points of zero displacement, it is established that displacement is zero when sin(kx)=0, which occurs at x=nπ/k, where n is an integer. The clarification confirms that x=0 is not the only solution for zero displacement; rather, it occurs at multiple points defined by the integer multiples of π/k. Understanding these points is crucial for analyzing wave interference patterns.
socoil23
given 2 waves y1=Ysin(kx-wt): y2=Ysin(kx+wt).
derive expression of resultant displacement and expression of x(for resultant) where displacement always zero
y=y1+y2
sinA+sinB=2sin((A+B)/2)cos((A-B)/2)
i solved first part:y= 2Y sin (kx) cos (-wt)
but i don't understand the 2nd part. does it mean y=0 when sin kx=0? mean x=0?
Is x = 0 the only value of x at which sin(kx) = 0?
I had figure it out.displacement is directly related to sin kx.displacement is Zero when kx equal to n*pai
where n is integer.displacement always zero when x = n*pai/k.
