Probability: Cumulative distribution problem
tsamocki
Example 5.1.4: Y is a continuous random variable on the interval (0; 1) with
density function
fY (y) =
{3y2 0 < y < 1
{0 elsewhere
what is the cumulative distribution function of Y ?
The relationship between a continuous random variable and the cumulative distribution function can be defined as: F(a) = P{X ∈ (-∞,α)} = ∫(-∞,α) f(x)dx
Is the problem just asking for this: P{Y ∈ (0,1)} ?
In terms of the integration, the indefinite integral is y^3 + C.
Alas i am stuck!
density function
fY (y) =
{3y2 0 < y < 1
{0 elsewhere
Alas i am stuck!
You wrote F(a) = ∫(-∞,α) f(x)dx. So, what is f(x) for x < 0? Can you replace the lower limit (-∞) by something else when a > 0? In other words, can you say
F(a) = \int_{\text{something}}^a f(x) \, dx, with 'something' ≠ -∞?
And NO: the problem is not asking you for P{Y ∈ (0,1)}; it is asking you for the cumulative distribution function (which you have already defined!).
RGV
RGV
You mean this:
F(a) = \int_{\text{0}}^1 y^3 \, dx,
Edit:
F(a) = \int_{\text{0}}^1 3y^2 \, dy,
Sorry, i previously responded via phone.
tsamocki said:
Edit:
The RHS is not a function of a.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
