Problem on entropy change and specific heat capacity
con31773
Calculate the change in entropy of the Universe as a result of the following
operations:
(a) A copper block of mass 0.4kg and thermal capacity 150JK-1 at 100◦C is
placed in a lake at 10◦C.
dS=dQ/T dQ=mCdT
Tried simply combining these equations and integrating to find change of entropy of block. Knowing that final temperature of the block will be approximately the initial temperature of the lake. So we get
mc[ln(T)] between boundaries of T1 and T2. However, this thermal capacity does not have the standard units for c, which is JK-1Kg-1, so I am questioning my whole approach. Assuming this is just some typo perhaps and I do indeed do this, I am not sure on how to find the universal entropy change. Any help would be greatly appreciated.
Many thanks in advance.
It's an obvious typo, so, what is the change in entropy of the block?
How much heat is transferred from the block to the lake?
At what temperature does the lake receive this heat?
What is the change in entropy of the lake?
What is the total change in entropy for the block plus lake?
Chet
Does it have to be a typo? The 0.4kg could just be a red herring.
Likes 1 person
True. Who knows?
Chet
Likes 1 person
It turns out It wasn't a typo, the C here was the heat transfer per unit temperature (multiple of C and M), something I was not familiar with. As a result the the question becomes much simpler, just being the sum of the two entropy change (block and lake)
Your help was much appreciated :)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
