Projectile explosion velocity and direction of fragments
The discussion centers on a physics problem involving the explosion of a shell fired horizontally at 200 m/s. Upon reaching the highest point, the shell explodes into three fragments: two equal mass fragments travel at 300 m/s, one in the direction of the shell's flight and the other perpendicular to it. The third fragment, which has three times the mass of each of the other two, must conserve momentum in both the horizontal and vertical axes. The solution requires applying the conservation of momentum principle to determine the velocity and direction of the third fragment.
  • Understanding of conservation of momentum in physics
  • Basic knowledge of projectile motion
  • Familiarity with vector components in three-dimensional space
  • Ability to solve equations involving mass and velocity
  • Study the principles of conservation of momentum in multi-body systems
  • Learn about vector decomposition in three-dimensional motion
  • Explore projectile motion equations and their applications
  • Investigate real-world applications of explosive dynamics in physics
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators seeking to explain the concepts of projectile motion and explosions in a classroom setting.
j_namtirach
A gun fires a shell with the horizontal component of its velocity equal to 200m/s. At the highest point in its flight, the shell explodes into three fragments. Two of these fragments, which have equal mass, fly off with speeds of 300m/s relative to the ground, one along the flight direction of the shell at the instant of fragmentation and the other perpendicular to it in a horizontal plane. Find the magnitude and direction of the velocity of the third fragment immediatley after the explosion, assuming its mass is three times that of each of the other two fragments. Neglect air resistance.
ρ = mv
I'm afraid I don't know where to start with this question. I was hoping somebody could at least set me off in the right direction. Any help would be appreciated. Thanks
Imagine the shell is fired in the x direction with y being the vertical. The other horizontal direction would be the z direction.
At the top the vertical velocity is zero so the shell is traveling horizontally in the x direction at 200m/s.
The first fragment continues horizontally in the direction of flight so (at least initially) it woud continue in the x direction.
The second fragment heads off perpendicular to the first in a horizontal plane so that would be in the z direction.
So before the explosion the shell has zero momentum in the vertical y axis. Two of the fragments also have zero momentum in the y-axis after the explosion. Applying conservation of momentum...
1)what does that tell you about the momentum of the third part in the y direction?
2)Is this really a 3D problem or a 2D problem?
It was less complicated than I at first thought. I've got it now!
Thanks a lot for the very clear explanation.
  • · Replies 41 ·
13K
