Projectile Motion: A boy throw a ball above a barn roof
The problem involves projectile motion, specifically determining the angle at which a boy must throw a ball to clear a barn roof that is 11 meters high, given an initial velocity of 12 m/s. The discussion also touches on the horizontal distance from which the boy must throw the ball, considering the ball starts 1 meter above the ground.
  • Participants discuss using the maximum height formula to find the angle but express confusion regarding the calculations and the missing time variable. There are attempts to combine vertical and horizontal components of displacement to solve for the angle and distance.
Some participants are exploring the feasibility of the problem, questioning the calculations that lead to an impossible angle. There is a suggestion to verify the maximum height achievable with the given initial velocity, indicating a productive direction in the discussion.
Participants note potential errors in calculations and the implications of the maximum height being insufficient to clear the barn roof, which raises questions about the assumptions made in the problem setup.
archcos
A boy attempts to throw a ball over the roof of a barn 11m high with an initial velocity of vsub0=12m/s. Determine the angle theta, at which the ball must be thrown so that it reaches its maximum height, which is at the roof of the barn. also find x where the boy must stand to make a throw, if the ball is thrown 1m from the ground.
x=vsub0*costheta*time
y=Vsub0sinetheta*time-1/2 gt^2
or if max height is given 11m maybe, h=vsub0^2sin^2theta / 2g
if i use equation for max height I can't get the angle but I am thinking of combining the vertical and horizontal comp of displacement if I could get some hints to solving the angle or maybe the total x distance, but I am stuck with a time missing then made me confused...
Why can't you find the angle using the max-height formula? It should work.
syntax error for me...i can't get the angle
Why? Show your work so we can see where you're getting stuck.
i get errors here
11=12^2sin^2theta / 2*9.8
11*2*9.8=144sin^2theta
√215.6/144=√sin^2theta
theta=arcsin(1.22) then error
That result (no real solution) indicates it's impossible for the boy to throw the ball over the roof of the barn.
The maximum height the ball could reach occurs if he were to throw it straight up. Try calculating what that is. If it's at least 11 m, there's no possible way for the ball to make it over the barn with that initial velocity.
  • · Replies 31 ·
  • · Replies 18 ·
  • · Replies 22 ·
27K
