Projectile Motion on the Moon: Finding the Optimal Launch Angle Using Equations
The discussion centers on determining the optimal launch angle for a cannon on the Moon to achieve maximum distance. It is suggested that the ideal angle is π/4, but if the projectile exceeds the Moon's escape velocity, an angle of π/2 could theoretically yield maximum distance. However, exceeding escape velocity complicates the situation, as the projectile would not return, making traditional distance calculations irrelevant. Participants emphasize the importance of understanding the underlying assumptions of projectile motion equations, particularly in varying gravitational conditions. The conversation highlights the need for mathematical backing rather than assumptions in solving physics problems.
Jonathan martin
A cannon can shoot whatever cannons shoot at different angles to the horizon, but with the same initial velocity. At what angle does the cannon shoot to a maximal distance? What would be that angle on the moon?
6cdb6b0652addd09d3b722bfb7e107dff0f1364a
  • d is the total horizontal distance traveled by the projectile.
  • v is the velocity at which the projectile is launched
  • g is the gravity
  • θ is the angle at which the projectile is launched
  • y0 is the initial height of the projectile
The maximum angle would be pi/4 (I am assuming), however if the projectile velocity was great enough to break the moon's escape velocity then the maximum distance could be given at an angle of pi/2. Thoughts?
You cannot go around just assuming things. You need to do the math to back it up.
If you exceed the escape velocity the constant gravitational field will be a very bad approximation. Furthermore the object will not come down so it would be irrelevant to talk about the ”length” ofa shot.
The maximum range formula makes certain assumptions about its area of applicability (as do several other commonly employed physics formulas involving motion and energy) Do you know what the assumptions are?
...if the projectile velocity was great enough to break the moon's escape velocity then the maximum distance could be given at an angle of pi/2. Thoughts?
Yes that's certainly true. How does this notion tie in with the assumptions alluded to above?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
