Projectile motion particle question
A particle projected from the origin with initial velocity v at an angle θ experiences motion under gravity, where its greatest height equals its horizontal range. The equations of motion reveal that the vertical and horizontal components of velocity are v_y = v sin(θ) and v_x = v cos(θ), respectively. To find tan(θ), the relationship between the maximum height and range is established by setting the time of flight equations equal. The maximum height occurs when v_y is zero, allowing for time calculations that can be substituted back into the range equation. The discussion concludes with a participant confirming they have understood the solution process.
misogynisticfeminist
A particle is projected from the origin 0 with initial velocity v at an angle of elevation \theta and it moves freely under gravity. Find tan \theta if the greatest height reached by the particle is equals to its range on the horizontal plane.
Using the equations of motion, i have found
\frac {v^2_y}{ 2g} = v_x t =v_y - 1/2 gt^2
but i am unsure of how to manipulate it from here to find v_y / v_x.
Use these
v_x = vcos( \theta)
v_y = vsin( \theta) -gt
x = vcos (\theta)t
y = vsin( \theta)t - g \frac{t^2}{2}
Then, the maximal heigth can be determined by realizing that v_y must be zero there. Calculate the time at which this occurs and put it into the formula for y. same goes for x (set y = 0 and calculate the time and put it into x) and then set these two equal to each other
marlon
hey thanks for the help marlon, I've gotten it...
