How do I calculate projectile motion when launching balls from a compressor?
To calculate projectile motion when launching balls from a compressor, first equate the work done by the expanding air to the kinetic energy of the ball, using the formula Ke = 1/2 mv². Consider the acceleration of the ball, which can be determined using momentum principles and Newton's second law (F=ma). The acceleration will vary throughout the ball's flight, initially being highest at launch and decreasing due to gravity until it stabilizes at 9.8 m/s². Accurate measurements and error tolerances are crucial for reliable results, and firing the ball straight up can help estimate the initial velocity while neglecting air resistance. Understanding these concepts will aid in effectively calculating the projectile motion.
knightryder
Hello everyone - here's my question: I am doing an assignment on projectile motion and I will be launching some balls from a compressor (that I have not seen yet!). I know how to calculate how much work will be done by the air expanding (will obv. depend on how much pressure is in the compressor); but i do not know how to go from there:
do i say that the work done will equal the kinetic energy of the ball and just use the simple projectile motion formulae? If i do, isn't that neglectling the time taken for the ball to accelerate?
If I take acceleration into account, i guess i would use momentum of air hitting ball = momentum of ball (elastic collision) then use f=ma on the ball. This will give me the acceleration of the ball. But how do I use the acceleration of the ball upwards with gravity taken into account? This would mean the acceleration would be highest at the launch, be 0 somewhere midair, decrease to 9.8 m/s then stay there? Perhaps there is an easy equation that I am forgetting (I would never rule that out!)
ummm.. that's what I am wondering..
if my first guess is right, then I use Ke= 1/2 m v2,
if my second guess is right , then I use Newton's 3rd.
Please read part 1.
Thanks for your help.
P.S. If possible use metric units- I am Grade 11 Australia.
Welcome to PF.
I suspect you already know, but here are the kinematic equations for motion once the ball is in flight.
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
And they an also be used to calculate your acceleration and initial velocity depending on what you are measuring.
As to your question about how complex ... that can be as complicated as you want it to be.
Your biggest problem will likely be in getting accurate measurements and determining your error tolerances. The easiest way to get a good crack at what your initial velocity is would be to fire the ball straight up and time its total time of flight. That of course ignores air resistance, which is certainly a factor, but it can give you a ball park working initial velocity.
Good luck.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
