Projectile problem-A rock is kicked off a 45 Degree hill at 15m/s.
The discussion revolves around a projectile problem where a rock is kicked horizontally at 15 m/s from a 45-degree hill. Participants express confusion over differing answers from their calculations compared to the textbook solution. It is clarified that the rock's trajectory must be analyzed in relation to the hill's slope, as the rock will not return to the launch height due to its horizontal launch. A key point raised is that the textbook may contain a misprint, suggesting the initial velocity should actually be 25 m/s instead of 15 m/s, which aligns with the correct solution. The conversation emphasizes the importance of accurately relating the x and y positions to determine the time of impact.
Kizaru
Projectile problem--A rock is kicked off a 45 Degree hill at 15m/s.
Hello. I tried this problem and it's the last one for my problem set due Thursday, but my answer differs from the given answer in the back of the book. After trying the solution again, I searched Google and found this. I'm having the exact problem.
A rock is kicked horizontally at 15m/s from a hill with a 45 degree slope. How long does it take for the rock to hit the ground?
Vix = 15m/s
Viy = 0
Yi = 0
Xi = 0
Vx = Vix
X = Xi + Vxo*t
Vy = Viy - gt
Y = Yi + Viy*t - (1/2)g*t^2
I tried equating the X and Y position functions, but this only provides the intersection between them--it does not provide the intersection between the rock and the hill. My second method is identical to the one described in the link mentioned earlier in my post. The problem is that my answer isn't the same as the one in the back of the book, and I'm not sure if it's a problem on my end. I don't know what to do after this. Any help would be great :)
If the rock lands at the same height it was launched one can obtain the time from the y position equation since y=0.
The rock will never pass that point because it's launched horizontally (no initial Y velocity) off a 45 degree hill (the hill is declining). The only time the rock is at y=0 is when t=0.
Imagine graphing y=-x and y=-x^2. If you focus on only the third quadrant, you have what looks like the hill (y=-x) and the path of the rock (y=-x^2), but it's not that easy to find an equation that represents the path of the rock.
Oh ok I get it. I thought it was launched off a 45 degree slope.
Well you know how the x position and y position are related (equation of slope) and you know how they evolve over time (kinematic equations). You can use both these bits of info to find the time.
For those getting an answer of 3.06 seconds, which disagrees with the back of the book, this is because there was a misprint. The actual velocity should be 25 m/s, not 15 m/s. The solutions manual also uses 25 m/s. Good luck!
