Proof Involving Integration by Parts and a Series of Functions
Tollschnee
Let f be continuous on an interval I containing 0, and define f1(x) = ∫f(t)dt, f2(x) = ∫f1(t)dt, and in general, fn(x) = ∫fn-1(t)dt for n≥2. Show that fn+1(x) = ∫[(x-t)n/n!]f(t)dt for every n≥0.
ALL INTEGRALS DEFINED FROM 0 to x (I can't format :( )
Integration by parts: ∫u dv = uv - ∫vdu.
I want to do this proof by induction. I am assuming the base step is when n=0 since that is the first possibility. This step is very simple because you can plug 0 into fn+1(x) = ∫[(x-t)n/n!]f(t)dt and get f1(x) = ∫f(t)dt.
Now the induction step is where I get messed up. I assume that fn = ∫(x-t)n-1/(n-1)! * f(t)dt. Also, I know that fn= (x-t)n/n! * f(t) based on the fact that fn+1(x) = ∫[(x-t)n/n!]f(t)dt = ∫fn(t)dt.
I have tried doing an integral by parts setting u = fn(t) ; du = fn-1(t) ; dv = dt ; and v = t... but I keep ending up with either sequences that don't mean anything or some annoying cyclical stuff where I end up right back where I started.
I think you are on the right track.
So f_1(x)=\int_{0}^{x}{f_0(x)} and f_n(x)=\int_{0}^{x}{f_{n-1}(x)} and f_{n+1}(x)=\int_{0}^{x}{f_{n}(x)}.
Here's the key insight:
If x is allowed to be any real number, then, first considering the definite integral and letting the indefinite integral of f_{n}(t) be \int{f_{n}(t)dt}=F_{n}(t)+C, we see that f_{n+1}(x)=\int_{0}^{x}{f_{n}(t)}=F_{n}(x)-F_{n}(0). This certainly looks as if it were saying that, for any value of x, we have that f_{n+1}(t)=\int{f_{n}(t)dt}+F_{n}(0) and, hence, f_{n+1}'(t)=f_{n}(t).
Once you have that, you can integrate by parts, and some things should become clear. I'll try to point you in the right direction.
Letting f_{n+1}(x)=\int_{0}^{x} I integrate by parts and obtain f_{n+1}(x)=xf_{n}(x)-\int_{0}^{x}{tf_{n}'(t)dt}. But, don't we know another way of expressing f_{n}(x)? We do, in fact, and as we are given that this can be expressed as an integral of another function. What about f_{n}'(t)? Well, because of the insight that f_{n+1}'(t)=f_{n}(t) I claim that this can be expressed as f_{n-1}'(t) and that, combining these two things I have stated here, you have something that may look familiar and you should be able to follow it through from there!
It's not a fact that
$$f_{n+1}(x) = \int \frac{(x-t)^n}{n!} f(t)\,dt.$$ That's what you're supposed to prove.
Another problem I see is in your definition ##f_{n+1}(x) = \int f_n(t)\,dt##. The lefthand side is a function of x, but x doesn't appear anywhere on the righthand side.
Tollschnee said:
∫[(x-t)n/n!]f(t)dt​
vela must have missed those limits of integration.
You could try sub/super-scripts.
0x along with larger size to make "∫" into "∫" .
That looks OK for the base step.
In line with what vela said: You are to prove
\displaystyle f_{n+1}(x) = \int_0^x \frac{(x-t)^{n}}{(n)!} f(t)\,dt\ ,\ not assume it.​
For the inductive step, I like to state something like:
Assume it's true that: \displaystyle f_{k}(x) = \int_0^x \frac{(x-t)^{k-1}}{(k-1)!} f(t)\,dt\ ,\ for some k ≥ 0.​
From that and using algebra & calculus you need to show that you can arrive at:
\displaystyle f_{k+1}(x) = \int_0^x \frac{(x-t)^{k}}{(k)!} f(t)\,dt\ ,\​
This is where you are likely to use integration by parts.
Do you see that logic behind the inductive process?
In the base step, you showed the general statement is true for k = 0 ( or n=0, depending on the index you use).
If you prove the inductive step, then the statement being true for k = 0, means that you showed it's true for k = 1.
The statement being true for k = 1, means that you showed it's true for k = 2.
The statement being true for k = 2, means that you showed it's true for k = 3.
etc.
So \displaystyle f_{n+1}(x) = \int_0^x \frac{(x-t)^{n}}{(n)!} f(t)\,dt\ \ is true for all n ≥ 0 .
Sure did. :redface:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
