Proof involving sequences of functions and uniform convergence
kidmode01
Let \phi_n(x) be positive valued and continuous for all x in [-1,1] with:
\lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) = 1
Suppose further that \{\phi_n(x)\} converges to 0 uniformly on the intervals [-1,-c] and [-c,1] for any c > 0
Let g be any function which is continuous on [-1,1].
Show that:
\lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) g(x)dx = g(0)
Theorem:
If the functions \{f_n\} and F are integrable on a bounded closed set E, and \{f_n\} converges to F pointwise on E, and if \Vert {f_n} \Vert < M for some M and all n = 1,2,3,..., then:
\lim_{n\rightarrow\infty} \int_{E} {f_n} = \lim_{n\rightarrow\infty} \int_{E} F
Alrighty, so the first thing I did was apply the theorem on:
f_n = \phi_n on the intervals [-1,-c] and [-c,1]
and came up with the following integrals(since uniform convergence implies pointwise convergence):
\lim_{n\rightarrow\infty} \int_{-1}^{-c} \phi_n(x) = 0
and
\lim_{n\rightarrow\infty} \int_{-c}^{-1} \phi_n(x) = 0
If we add these integrals together we know what happens at c=0.
Looking at our new sequence:
f_n = \phi_n g(x)
This sequence is uniformly bounded on [-1,-c] and [-c,1] and converges pointwise to 0.
Thus I think because of the continuity of \phi_n and g, and the uniform convergence of \phi_n:
\lim_{n\rightarrow\infty} \int_{-1}^{-c} \phi_n(x) g(x) = 0
\lim_{n\rightarrow\infty} \int_{-c}^{-1} \phi_n(x) g(x) = 0
Again if we add these integrals together we know what happens when c = 0. But I'm not entirely sure where to go from here or if I'm going in the right direction. Any help is appreciated.
Second attempt at solution
Okay so I've tried a little bit more now:
Just adding and subtracting a term from the limit we want to prove:
<br /> \lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) g(x)dx = <br /> \lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x)(g(x)-g(0))dx + \lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) g(0)dx<br />
but
\lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) g(0)dx = g(0)
and by the mean value theorem for integrals we know there exists a t in [-1,1] such that:
\lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x)(g(x)-g(0))dx = (g(t)-g(0))\lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) = g(t) - g(0)
and now I want to make an argument that states g(t) must be g(0).
So I started by breaking my integral up:
<br /> \lim_{n\rightarrow\infty} \int_{-1}^{-c} \phi_n(x) g(x) + \lim_{n\rightarrow\infty} \int_{-c}^{1} \phi_n(x) g(x) = 0<br />
as c goes to zero.
But then g(t) - g(0) = 0 and thus g(t) = g(0) and then we would have:
<br /> \lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) g(x)dx = \lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x)(g(x)-g(0))dx + \lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) g(0)dx = g(t) - g(0) + g(0) = g(0)
The very last step seems a little hand wavy, I hope someone can help me.
Edit: (I also realize some of the stuff in my first post is wrong, but it won't let me edit it)
You MUST mean phi_n converges uniformly to zero on [-1,-c] and [c,1] for any c>0. Not [-1,-c] and [-c,1]. If that were the case then the integral of phi_n would go to zero as n->infinity.
Right, thanks for pointing that out.
Then my integrals at the bottom of my second post change to:
<br /> <br /> \lim_{n\rightarrow\infty} \int_{-1}^{-c} \phi_n(x) g(x) + \lim_{n\rightarrow\infty} \int_{c}^{1} \phi_n(x) g(x) = 0<br /> <br />
and then as c goes to zero:
<br /> 0 = \lim_{n\rightarrow\infty} \int_{-1}^{-c} \phi_n(x) g(x) + \lim_{n\rightarrow\infty} \int_{c}^{1} \phi_n(x) g(x) = \lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x)(g(x)-g(0))dx = (g(t)-g(0))\lim_{n\rightarrow\infty} \int_{-1}^{1} \phi_n(x) = g(t) - g(0)
Edit: Ya this is wrong.
I just don't feel right about this though.
Ah I'm all messed up now lol
g(x) is continuous at 0. So if c is small enough g(x) is 'almost' g(0) on [-c,c]. phi_n is 'almost' zero outside of [-c,c] for large enough n. Now put in some epsilons to quantify 'almost'.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
