Prove its Gauss curvature K = 1
  • Thread starter Thread starter Shackleford
    Curvature Gauss
Shackleford
Assume that the surface has the first fundamental form as
E = G = 4(1+u2+v2)-2
F = 0[/B]
K = \frac{-1}{2\sqrt{EG}}[(\frac{E_v}{\sqrt{EG}})_v + (\frac{G_u}{\sqrt{EG}})_u][/B]
Ev = -16v*(1+u2+v2)-3
Gu = -16u*(1+u2+v2)-3
When I take the partials and find K, I get something messy that doesn't lead me to the conclusion that K = 1.[/B]
Start by substituting E=G and \sqrt(EG) = |E|.
What did you end up with?
Thanks for the reply. I found my error a little bit ago. For some reason, I kept using the denominator of E and G AS E and G. -_- It was late, so I'll credit it to sleep deprivation. Heh.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
