Prove that the functin is differentiable at (0, ,0).
  • Thread starter Thread starter michonamona
    Differentiable
michonamona
Let r>0, and let f be a function from B_{r}(\textbf{0}) \rightarrow \textbf{R}, and suppose that there exists an \alpha > 1 such that |f(\textbf{x})| \leq ||\textbf{x}||^{\alpha} for all \textbf{x} \in B_{r}(\textbf{0}). Prove that f is differentiable at 0.
What happens to this result when \alpha = 1?
Note:
The characters in bold are vectors.
B_{r}(\textbf{0}) is an open ball in R^{n} about 0
The symbol ||.|| represents the norm of the vector.
Some definitions of differentiability of a function
A function f from R \rightarrow R^{n} is differentiable if
lim_{\textbf{h} \rightarrow \textbf{0}} \frac{f(\textbf{0} + \textbf{h}) - f(\textbf{0}) - Df(\textbf{a})(\textbf{h})}{||\textbf{h}||} = \textbf{0}.
Where Df(\textbf{a}) is the matrix of first order partials. In our case, since the function is from R to R^n, this would be the gradient of f.
The started this problem by computing that the first order partials exists. But that by itself is not sufficient to concluded that f is differentiable at 0. The next step would be to show that the first-order partials of f are continuous at 0. This is where I got stuck.
Can you explain what you are thinking about this problem?
Hi Euler,
Thank you for your reply.
There's a theorem in my textbook that says that if the first-order partial derivatives of a vector-valued function f exists at a, and if these first-order partial derivatives are continuous at a, then f is differentiable at a.
I know how to show the existence of the first-order partial derivatives of f at 0, but I'm having trouble proving that they are continuous at 0. Any insights?
I see how you are stuck. Have you thought about avoiding this theorem, and working directly from the definition of the derivative?
You mean using:
directly?
yes.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
