Proving B.(Gradient . B) - B X (Gradient X B)=Del{i}B{i}B{j}
  • Thread starter Thread starter hellomynameisscottt
hellomynameisscottt
I need to prove B.(Gradient . B) - B X(Gradient X B)=Del{i} [B{i}B{j} -1/2 (kroneker delta {ij} B^2]
where I have used . as the dot product, {} as subscript. Thank you!
[/B]
I have attempted the solution but am not sure how it is possible to keep a kroneker delta on the right hand side.
I can not read your complete statement above, but this looks like it comes from a standard vector identity: (where ## A ## and ## B ## are both equal to ## B ##).
## \nabla (A \cdot B)=(A \cdot \nabla) B +(B \cdot \nabla) A+A \times \nabla \times B+B \times \nabla \times A ##
I have uploaded the page from Jackson it is equation (6.119) I am trying to prove, however I must use Levi Cevita notation.
On the left side of the equation in your OP, they are only taking one component. You may be able to use the identity I presented to simplify the ## B \times \nabla \times B ## term.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
