Pulley & Block Problem: Forces & Acceleration
  • Thread starter Thread starter bsmith2000
    Blocks Pulley
The problem involves a rectangular block on a table with two masses connected by a string over a pulley. The discussion centers around analyzing forces and accelerations in a frictionless environment, with specific tasks including drawing free body diagrams and calculating forces and accelerations based on given conditions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss drawing free body diagrams for the masses and the block, questioning the necessity of certain forces. There are attempts to derive expressions for the external force needed to keep the system stationary and to find initial tensions and accelerations after release. Some participants express uncertainty about the relationships between the forces and accelerations involved.
Several participants have offered insights into the problem, with some suggesting algebraic relationships between the forces and accelerations. There is an ongoing exploration of how to approach the problem using free body diagrams, and while some guidance has been provided, there is no explicit consensus on the correct methods or final answers.
Participants note that the problem assumes all surfaces are frictionless and that there are specific conditions under which the masses are held before being released. There is also mention of the need to ensure that solutions for different parts of the problem are consistent with one another.
bsmith2000
A friend of mine gave me this problem, and it was somewhat hard:
A rectangular block of mass M1 rests on a horizontal table. Masses M2 and M3 are free to slide along the surfaces of M1 and are attached by a massless string over a frictionless pulley.
For the diagram, go to: http://img451.imageshack.us/img451/7456/28142628dx2.jpg[/PLAIN]
Also, assume all surfaces are frictionless.
a) Draw free body diagrams for M1 and M2. Assume the pulley makes a 45 degree angle with the horizontal.
b) Find the external force F that should be applied to M1 so that M3 will stay at a fixed height above the table. (meaning M2 and M3 don't move relative to M1)
c) Suppose there is no external force. All masses are held fixed up until time t=0, and then they are released. Find the initial tension in the string T, and the initial acceleration a of M1 just after being released. Express the answer in terms of the masses given and g.
My thoughts so far:
For a), on M1, I drew the normal force it had with the table and the gravitational force. Do I need to draw some sort of normal force for the contact it has with M3? The M2 diagram has its normal force with M1, gravity, and the tension force to the right.
For b), I thought the force would be M3*g, because that is the tension force, so applying that force would somehow counter it? It is somewhat of a wild guess, and I am pretty sure it is incorrect, b/c that seems too easy.
For c), I don't see how how M1 would even accelerate, nor do I see how the "initial" tension would ever change after time.
Whoops - sorry, I didn't know we had to place questions in a separate forum.
Anyone have any insight to this problem?
for part b, x: (M1+M2+M3)(a)=F_x. solve for a. Since you want it to remain stationary, a_y=0=T-M3g. (M2)a_x=T. So then you have the acceleration you solved for multiplied by M2 and that will equal M3g. Do algebra to get F= M3g(M3+M2+M1)/M2.
for part a, you don't have to draw a force for the contact. it is assumed that friction is negligible and won't affect it.
for part c, the tension will remain the same seeing as though the length of the string and the masses do not change. Therefore, you are correct and the "initial T" will be the same until the block reaches the ground. So, T=M2M3g/(M2+M3)
Thank you so much pgraves013! That makes so much sense!
Do you know how to find the initial acceleration of mass M1 just after the masses are released? (there is no external force during that part)
I think that the application of pseudo force would make it even easier.
Are you familiar with pseudo forces?
since the blocks are all connected in one way or another, i think that the acceleration of each would be the same. I am really not sure though, but i think it may be a=M3g/(M1+M2+M3). I'm not 100% sure, but i think that is correct
Hi, I need help with this similar problem and to make things short, I also found that
a = m3g/m2 from part b which states: Find the force F by ONLY using the separate free body diagrams of M2, M3, and M1+M2+M3.
so for M1+M2+m3 F=(M3g/M2)(M1+M2+M3)
but for my part c it says: Find the force F by ONLY using the separate free body diagrams of m1, m2, and m3. (The force from part b and c should agree! Make sure your answer is in terms of m1, m2, m3, and g)
And when it comes to this I found that F=(M1+M3)(M3g/M2) . . . . :(
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 102 ·
9K
