Solve Pulley Problems: Friction & Inertia | Physics Help
  • Thread starter Thread starter blackice552
    Pulley
The discussion revolves around solving two pulley problems involving friction and inertia. The first problem involves two masses (21.5g and 39.8g) and requires calculating the frictional force of the pulley, with a given graph slope of 6.77 1/N. The second problem features different masses (55.9g and 41.8g) and provides an intercept of 0.04s²/m, with a known frictional force of 0.31N, aiming to find the inertia of the pulley. The user expresses frustration with their attempts, indicating significant confusion despite studying the concepts extensively. The thread highlights the complexities of applying physics equations to real-world scenarios involving pulleys.
blackice552
I have to problems that I'm having trouble with today I just can't seem to get my head around a lot of these physics concept so I'm finally coming here Plz help me. I've tried to do these problems and I just don't know what I'm doing.
1.We have two masses hanging from a pulley of inertia mp and constant frictional force f. One mass is 21.5g and the other is 39.8g. When data is taken, the slope of the 1/a vs. (m1 + m2) graph turns out to be 6.77 1/N. What is the value of the frictional force of the pulley? (2 decimals and UNITS!) (g=9.8m/s2)
We have two masses hanging from a pulley of inertia mp and constant frictional force f. One mass is 55.9g and the other is 41.8g. When data is taken, the intercept of the 1/a vs. (m1 + m2) graph turns out to be 0.04s2/m and the frictional force of the pulley 0.31N. What is the value of the inertia of the pulley? (2 decimals and SI UNITS!) (g=9.8m/s2) (If you get a negative answer type it in even though it doesn't make sense physically)
These are the equations I have:
for no friction:
1/a = (m1 + m2)/((m1 -m2)g)
for a system with friction:
(m1 - m2)g - f = (m1 + m2 + mp)a
1/a = [(m1 + m2)/((m1-m2)g - f)] + [mp/((m1-m2)g -f))]
My solutions were totally outrageous I have no idea what I'm doing frankly I've studied this stuff for hours and can't wrap my head around it
.For the first problem:1/a = (21.5 + 39.8)/((21.5 - 39.8)9.8)f = (21.5 - 39.8)9.8 - (21.5 + 39.8)6.77 f = -3.45 NFor the second problem:(55.9 - 41.8)9.8 - f = (55.9 + 41.8 + mp)0.04mp = ((55.9 - 41.8)9.8 - f)(25.1/0.04) - (55.9 + 41.8)mp = 0.31 N * 25.1/0.04 - 97.7mp = 7.60 kg
