Pulley with three masses what is T1?
  • Thread starter Thread starter gap0063
    Pulley
The discussion focuses on calculating the tension T1 in a pulley system with three masses: 3 kg, 2 kg, and 6 kg. Participants clarify that the tension in the string between the two left-side masses (T1) differs from the tension in the string over the pulley (T2). They emphasize the need to set up separate equations for each mass using Newton's second law. After several calculations and corrections, the final tensions are reported as T2 = 32.0727 N and T1 = 19.2436 N. The conversation highlights the importance of accurately applying equations and understanding the dynamics of the system.
gap0063
A pulley is massless and frictionless. 3 kg, 2 kg (on the left), and 6 kg (on the right) masses are suspended
(a)What is the tension T1 in the string between the two blocks on the left-hand side of the pulley?
(b) What is the magnitude of the acceleration of the lower left-hand block?
My prof gave an example T=m1g=m1a
m2g-t+m2a
Can I solve this like if it was two masses?
m2g-t+m2a
then we solved for T in equation one and plugged it into equation two... in that problem the Tension was the same on both sides but in the picture on the problem they have labeled them T1, T2 and T3 so I'm not sure
The tension in one string is the same. Hence if you just have two masses on either side of the pulley the tension of the string will be the same on both sides.
But this time on one of the sides there are two masses. The rope between these two masses has a different tension than the rope over the pulley connecting the other two.
So if T1 is the tension in the rope between the two masses on the same side then:
T1-m1g=m1a
if T2 is the tension in the other rope then:
T2-m2g-T1 = ...
and:
m3g-T2= ...
I will leave you to figure the ... out ;)
You can solve it using the same general technique, but you need to calculate the tension for each string separately. You should be able to make a Newton II (Fnet=mblockasystem) equation for each block. Then solve the equations for T1 (or whichever tensions you need) and asystem.
T1-m1g=m1a
T2-m2g-T1 = ...
and:
m3g-T2= ...
a=(m3-m2)/(m2+m3)*g
So I got T2= m2(g+a) => plug in a... and I got T2=29.4N
Then I used T2-m2g=m2a to get a=T2-m2g-m2
and plugged this a into T1-m1g=m1a and got T1=44.1N which is wrong...
Where did I go wrong??
you calculated the acceleration wrong.
Dont leave out the T1 from the second equation ;)
Your equations should be:
T1-m1g=m1aT2-m2g-T1 = m2am3g-T2= m3T3
T1-m1g=m1a
T2-m2g-T1 = m2a
m3g-T2= m3T3
I used the last equation to solve for T2(which isn't T2=T3) and got T2=8.4 N
Then using the first equation I solved a= T1-m1g/m1 and plugged it into the second equation and got T2-m2g-T1=m2(T1-m1g/m1)
and got T1=5.04 N which is wrong...
Oh wait, that was a typo sorry, it should be:
m3g-T2= m3a
the previous equation didnt make any sense..;)
m3g-T2= m3a
Should T2 be bigger than T1?
I got T2=32.0727 N and T1= 19.2436
