Pulse Jet Go-Kart Plans: 80-100lbs Thrust Gas Fuel
  • Thread starter Thread starter wolram
    Jet Pulse
Plans for a valve-less pulse jet engine capable of 80 to 100 lbs of thrust are sought for a novel go-kart project using gas as fuel. A link to a DIY engine with 75 lbs of thrust is shared, highlighting the complexity of atomizing gasoline for safe operation. Concerns about the dangers of such a project are raised, with suggestions to consider simpler alternatives like a motorcycle engine. The original poster expresses ambition, planning to start with one engine and potentially adding a second for increased speed. The discussion emphasizes both the excitement and risks associated with building a pulse jet-powered go-kart.
wolram
Dearly Missed
Can anyone tell me where i might find plans for a valve less
pulse jet engine, with a thrust of about 80 to 100lbs, i want
to use it to power a novel gocart. i want to use gas as the
fuel if possible.
Hehehe, this sounds sweet!
Plans for a 75 lb thrust do it yourself engine.
http://blastwavejet.com/pulsejet.htm
Your idea sounds really cool.
After watching the Junkyards Wars episode where they built one of these and reading online I thought this was a dangerous enough concept. But with gasoline instead of propane so now you need to atomize the fuel properly to add yet another level of complexity - wow. You sir, are one ambitious guy. I would take the lazy way out and get a salvage motorcycle motor and call it a day. :smile:
Cliff
Thanks everyone,
I plan to start with one engine, but if that is to slow i may use two, bolted
to a stock kart, and hopefully kick up a rumpus at the local drag strip.
any one have fire proof overalls spare?
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
